What is control hydraulic unit.?
Old Jul 10, 2020 | 06:45 AM
Braq33's Avatar
Default What is control hydraulic unit.?
Profissionals, I need help.Recently I replaced damged xj ECU with s-type ECU .I cloned the data with t-tag.The car started fine but when you drive it is not accelerating but when it's stopp it accelerating normally.When I check it with jlr it gives me U0300 as indicated in the picture.What is control hydraulic unit.
thanks
Old Jul 10, 2020 | 09:32 AM
JagV8's Avatar
See top right where it says ABS.
In reality your attempted fix may be the cause.
Old Jul 10, 2020 | 01:47 PM
motorcarman's Avatar
As JagV8 stated, it is the ABS hydraulic control.
See Actions required...
Check anti-lock control - stability assist module for DTCs...............
drsolly
XJ220
Apr 10, 2020 02:25 PM
bdevid12
Aug 30, 2019 12:22 AM
David.Lipowski
Oct 18, 2018 02:57 PM
dannio636
Jul 3, 2016 05:41 AM
meeither
Nov 3, 2012 10:20 PM
