What did you do to your X350/X358 today?
Old Jun 22, 2017 | 07:04 AM
  #261
romroc's Avatar
Originally Posted by StellaLunaGardens
I had The coolant reservoir hose develop a crack on me, while driving. I MacGyver'ed it with a knife from Walmart. The next day, I broke the plastic tip on the overflow reservoir taking the damaged hose off. After a week the new reservoir arrived, and I decided, while I was in there, I would replace all the hoses and the thermostat and thermostat housing.
I have all the hoses, but one, hopefully the dealer can identify it for me, so I can get her back together soon.
Good Shew, i need to learn more about all this.
Old Jun 22, 2017 | 12:15 PM
  #262
XJ8JR's Avatar
I hate that damn coolant tank. I've gone through three of them within the past 7 years. Each one failed in exactly the same place. Thankfully they're cheap and easy to replace.
Old Jun 22, 2017 | 08:13 PM
  #263
romroc's Avatar
Just a thought: I had a weed trimmer fuel tank that leaked at a through wall grommet and I used a fuel proof epoxy on the leak. It has been dry ever since. it might be possible to use a plastic epoxy to seal the area. They can be amazingly strong, witness the repair I did. BTW, the grommet and Jaguar's tank are not very good, but can be improved in the field, IMO.
Old Jun 23, 2017 | 11:00 AM
  #264
XJ8JR's Avatar
That might be a good idea to reinforce the area beforehand to keep it from breaking at all. But then the hose might not fit over it properly.
Old Jun 23, 2017 | 03:36 PM
  #265
romroc's Avatar
In other words, fly me to the moon.
Old Jun 23, 2017 | 05:27 PM
  #266
Muleears's Avatar
Default New tires
Bought a pair of new Continental ExtremeContact DWS06 tires to replace the ORIGINAL conti's that were still on the car at 14 years of age... To bad too, still have good tread on them.
Tomorrow I will attempt the removal/repair/re-installation of the suspension compressor piston seal.
Old Jun 23, 2017 | 05:49 PM
  #267
JagsteRJX's Avatar
Swore at it @&#@. Another front air strut perished.
Old Jun 23, 2017 | 07:24 PM
  #268
romroc's Avatar
What are the age/miles?
Old Jun 23, 2017 | 08:24 PM
  #269
JagsteRJX's Avatar
2006 XJR 93k miles. I just replaced the original on the passenger side in November, now the already replaced re-manufactured is leaking on the driver's side, a previous owner had it installed.
Old Jun 24, 2017 | 04:36 AM
  #270
romroc's Avatar
My 04 purch May has Arnott's front, orig rear. Florida rebuilder doesn't change shocks, only airbags/orings. You would think that Bilstein would have some sort of program. On Ebay, used low milleage units appear, but you are time limited. I thought go coils front only, but what about computer? Used single unit a temporary answer. Real shame, the fly in the ointment.
Old Jun 24, 2017 | 04:46 AM
  #271
romroc's Avatar
My 04: Arnott front, stock rear, 129k miles. Bought used/serviced pump, all is well. No program from Bilstein? Not good. Fla rebuilder does not do actual shocks, only bags and related. Excellent concept, poor field support. Ebay/used, if can wait. That's where nice pump came from.
Old Jun 24, 2017 | 07:09 AM
  #272
Fraser Mitchell's Avatar
I don't think the shock part of the unit can be dismantled, but may be wrong on that one. Bilstein sell their own units on the aftermarket, but they are very costly albeit a load less than if you buy one from a Jaguar dealer.
Old Jun 24, 2017 | 09:18 AM
  #273
JagsteRJX's Avatar
The original & Arnott reman sports struts are somewhat stiffer than the new Arnott 2890 sport. When pushing down on the corners of the car the originals & the reman don't really give much, the new Arnott 2890 moves a lot more. When speaking to Arnott they said the 2890 should be the same as the OEM. It's nowhere near as firm. I don't really notice any difference when driving though.
Old Jun 24, 2017 | 11:33 AM
  #274
romroc's Avatar
Just put a battery tender in, have to wait for title cert., started engine, pump ran a bit, no fault lights at any time. Kant wait, car wants to MOVE.
Old Jun 24, 2017 | 05:14 PM
  #275
meirion1's Avatar
My solution to the plastic tank problem.
Never used in anger (yet)
Attached Thumbnails What did you do to your X350/X358 today?-img_0371%5B1%5D.jpg
Old Jun 24, 2017 | 05:54 PM
  #276
romroc's Avatar
That looks good!
Old Jun 24, 2017 | 06:26 PM
  #277
Muleears's Avatar
Default Well, I got it done! Installed bagpipingandys piston ring
The worst part was taking the compressor out and getting it back in..... I had to do it with the tire in place because I used ramps. What a PITA. I need to learn how to take the bumper off, I think that would be easier. Anyway, the install of the ring once the compressor was out was a piece of cake. Put it all together, buttoned it up, took her for a drive and NO ASF warning!
It had been giving me one every other trip, only really took one trip today so I'll do some more extensive testing tomorrow and hopefully the ASF will stay away!
Old Jun 24, 2017 | 07:22 PM
  #278
romroc's Avatar
Nice not having those lights on! I now have two pumps and cleaned out and baked the dessicant in the oven (wife not home!). The orifices are tiny, the tube to mains is similar. Pressure, but not much volume. Oh well, good luck, she's a beaut I'm sure.
Old Jun 25, 2017 | 06:42 AM
  #279
jackra_1's Avatar
Default Replaced parking assist module
I finally got around to replacing my parking assist module. Bought a replacement on Ebay and had it installed and working in 10 minutes.
Also installed projector door lamps.
Attached Thumbnails What did you do to your X350/X358 today?-p1140061.jpg
Old Jun 25, 2017 | 06:54 AM
  #280
romroc's Avatar
What does the module do?
