Where is the MAP Sensor on an XJR?
Old Sep 5, 2015 | 09:04 PM
Donzi's Avatar
Default Where is the MAP Sensor on an XJR?
Hi Gang, I have searched the forum and looked on my engine for 2 hours,
Where the heck is the MAP sensor located on my 2004 XJR ?
Thanks!
Old Sep 6, 2015 | 12:33 AM
Don B's Avatar
Originally Posted by Donzi
Where the heck is the MAP sensor located on my 2004 XJR?
Hi Donzi,
I'm attaching two pages from the 2004 Technical Guide that should help you find the MAP sensor. The diagram shows the supercharged engine as viewed from approximately the driver's seat. The MAP sensor is Part 9 in the diagram. It's tucked down behind the throttle body near the EGR Valve, Part 7. I can see why it would be hard to find!
Cheers,
Don
Old Sep 6, 2015 | 06:39 AM
Donzi's Avatar
Thank you sir!
Old Sep 6, 2015 | 08:35 AM
Donzi's Avatar
UPDATE!
After removing the air plenum, I was able to feel (not see) the MAP sensor, the connector was unplugged! By feel only, I was able to plug it back in...and now NO check engine light and no P1108 code!! Very happy!!
Old Sep 6, 2015 | 08:52 AM
trosty's Avatar
Love simple happy endings.
Old Oct 17, 2018 | 07:05 AM
EsRay's Avatar
Originally Posted by Don B
Hi Donzi,
Don
Hello Don,
Is this different to the Workshop manuals? If so, do you have the Technical Guide for the N/A, please? I would like an N/A version of that S/C diagram!
Old Oct 17, 2018 | 08:51 PM
Don B's Avatar
Originally Posted by EsRay
Hello Don,
Hi EsRay,
Yes the Technical Guide is different from the Workshop Manual. See pdf pages 90-91 of the document below for the N/A diagram:
Jaguar X350 Technical Guide 2004-2005
Cheers,
Don
Old Oct 18, 2018 | 12:26 AM
EsRay's Avatar
Hi EsRay,
Cheers,
Don
Thanks Don,
The drawings in this Tech Guide are of better quality than those in the Workshop Manual and are also better at showing exactly where the parts drawn are located. I think this is a valuable aid to the Workshop Manual and perhaps should be included in the 'Stickies'?
Forcedair1
Sep 8, 2025 01:57 PM
Shawn Svacha
Feb 6, 2022 04:53 PM
adam699
Sep 12, 2015 05:32 PM
motorhead69
Sep 9, 2015 10:04 AM
pegasus3710
Sep 5, 2015 09:40 AM
