wiper blade source
Old Apr 4, 2009 | 09:36 PM
chadmc5c's Avatar
Default wiper blade source
Anyone have a source or part number for the skinny wiper blade refills?
I found the shorter passenger side one at NAPA but the drivers side (longer one) is not available in the skinny type.
Would like to keep the stock setup if possible.
Cheers,
Chad
'06 xj8
Old Apr 4, 2009 | 11:54 PM
bmw745ion19s's Avatar
Hey C, hope life has been treating ya well! someone recently made a post about a kit you can buy off of ebay with bosch icon style wiper blades but work with the washers mounted on the arms
https://www.jaguarforums.com/forum/s...ad.php?t=11931
I think it would be worth a try, not sure if those type are your style but i love them on my cars.
-Erik
Old Apr 5, 2009 | 08:36 AM
panels's Avatar
Cheers,
Chad
'06 xj8
455-245 part number at Carquest. It's a trico blade rebranded. Fit perfect...
Old Apr 6, 2009 | 10:37 AM
chadmc5c's Avatar
Thanks fellows.
I'll try the carquest first. Thanks for adding the p/n!
Chad
Old Apr 8, 2009 | 07:36 AM
mosesbotbol's Avatar
Originally Posted by panels
190-245 part number at Carquest. It's a trico blade rebranded. Fit perfect...
Is that the refill for both sides? I need to replace my inserts as well.
Old Apr 8, 2009 | 08:26 AM
panels's Avatar
I was mistaken...
right is 455-190
left is 455-245
Not exactly sure on the 15- but the 190 and 245 are correct and fit perfect. These are refill blades and you will need a needle nose pliers to squeeze the old blade out of the wiper arms.
Tom
Old Apr 8, 2009 | 04:17 PM
chadmc5c's Avatar
I found the short side at Napa The longer one was too fat to fit the wiper claw.
(It was 8mm wide and the claw is 6mm)
I found the longer one (drivers side) at Carquest. Their p/n 455-245.
I bought two longer ones so I don't have to go through this again.
I don't have the p/n for the shorter one from Napa at hand.
It seems the shorter one is easy to find. The narrow fit at 6mm goes up to a 22inch length and after that >24 they're 8mm wide. A 24 inch insert with the narrow (6mm) claw is the one you have to search for.
hth,
Chad
(man I never thought wiper blades would be such a PITA!)
Old Apr 8, 2009 | 05:55 PM
mattrains's Avatar
Jaguarparts.com has them but they dont show a part number with it, so you have to search for it. Its $21.17 for each side
Mat
Old Apr 14, 2009 | 03:18 PM
chadmc5c's Avatar
Inserts (refills if you prefer) were about 5 bucks at Napa and Carquest.
With all the rain we had last night I was glad I had new blades on the wipers.
C
Old Feb 28, 2011 | 07:15 PM
amcdonal86's Avatar
Anyone have the correct part numbers from NAPA?
Old Mar 1, 2011 | 09:21 AM
Drew's Avatar
For a full arm replacement the Napa Teflon line works too.
kthrash's Avatar
NAPA Part #'s
Drivers: WIP 602401
Passenger: WIP 601900
I just purchased them there and they had to order them from the warehouse.
Old Mar 1, 2011 | 09:22 AM
kthrash's Avatar
It fits the Jaguar Clip with the sprayer?
Old Mar 1, 2011 | 11:26 AM
amcdonal86's Avatar
Yeah, I was wondering if it requires any adapters!
Old Mar 12, 2011 | 05:42 PM
tvn300's Avatar
Just found out that the Trico Teflon line (Advance Auto, and many other sources) will accept the Jaguar insert perfectly. New arm, new blade, old washer system. Works perfectly. About 18 bucks apiece.
Old Mar 12, 2011 | 06:56 PM
amcdonal86's Avatar
So it just snaps in?
Old Mar 13, 2011 | 11:23 AM
haggis95's Avatar
I went to the dealer. $20 for the pair. Couldn't find them anywhere else.
Old Mar 13, 2011 | 03:28 PM
tvn300's Avatar
Default Wiper Blades
Yes, just snaps in. If you disasemble the wiper blade from the wiper arm, the wiper arm is the typical type with a "J" hook at the end. The plastic clip (which contains the windshield washer jets) will simply unsnap from the old wiper blade, and you snap it into the new wiper blade. Done! Actually quite easy, once you see it all apart. And this allows you to use an aftermarket wiper blade but still gives you a much higher quality blade than the "refill-only" style--these are apparently being phased out because the parts stores make a lot more money selling a 20 dollar blade than a 3 buck refill...
Old Mar 15, 2011 | 09:26 AM
kthrash's Avatar
ok, I just ordered Trico Teflon Blade 15-240 and 15-190 from Amazon.. we shall see if they fit. $29.86 shipped.
I could not find them locally.
Old Mar 15, 2011 | 11:31 AM
Road_King's Avatar
OEM inserts are $11.60 each at Nalley. Talk to Dan and tell him you're a Jag Forum member.
