Workshop manuals & Torque Wrench settings
Old Apr 22, 2018 | 06:49 PM
The Moneypit's Avatar
Default Workshop manuals & Torque Wrench settings
All the necessary parts for an in-depth 100'000 miles service of my X350 XJ6 will be ordered tomorrow. I'll be ordering these through my local Jaguar main dealer, (Hatfields of Sheffield), as I found their prices to surprisingly be very reasonable and all bar a couple of items, exactly the same price as one of the main aftermarket Jaguar parts suppliers.
There is however, just one small problem....
I'm reasonably competent with the spanners, but even so, it's nice to have a Haynes Manual by my side, just to refer to if I get a little stuck, plus there's the torque wrench setting in there, (for spark plugs for example). Sadly, no Haynes Manual is available for the X350. Am I correct to assume that a Haynes Manual for the X-Type, (also with the 3.0 V6), would offer accurate torque wrench settings for all under bonnet components of the XJ6?
In advance, many thanks.
Old Apr 23, 2018 | 02:23 AM
JagV8's Avatar
Very possibly not.
If you're desperate you could risk using them as a guide.
Does JTIS not cover your car? (It has lots of such specs.)
If not, I suspect there are files about your car either on this site or JagRepair.com - Jaguar Repair Information Resource (maybe both) and of course worst case on jag's TOPIX.
Old Apr 23, 2018 | 04:27 AM
Originally Posted by JagV8
Very possibly not.
Ah. That's disappointing. I've just nipped down to Halfords to buy a X-Type Haynes manual. I assumed, perhaps incorrectly, that as the 3.0 X-Type and the XJ6 use the, (as far as I am aware), exact same Duratec V6, that the torque wrench settings for all engine related stuff, (spark plugs, head bolts, etc), would be the same? As far as I can tell, the only real difference is how the engines are located in the two cars. Longitudinally in the XJ, transversely in the X-Type.
Many thanks for the two links that you provided. I'll have a browse through those in a little while after I've come back from collecting the servicing parts I need from Hatfields.
Old Apr 23, 2018 | 05:17 AM
Originally Posted by The Moneypit
..... Am I correct to assume that a Haynes Manual for the X-Type, (also with the 3.0 V6), would offer accurate torque wrench settings for all under bonnet components of the XJ6?
Assumption is a dangerous thing.
From the X350 Workshop Manual:
Attached Thumbnails Workshop manuals & Torque Wrench settings-torque-1.jpg   Workshop manuals & Torque Wrench settings-torque-2.jpg
orangeblossom
Apr 8, 2018 04:33 AM
Griff79
US Central
May 9, 2017 09:20 AM
orangeblossom
Oct 23, 2016 02:38 AM
matade
Sep 18, 2011 07:22 AM
