X350 Drivers door lock problem
Old May 7, 2017 | 07:02 AM
danthefitter72's Avatar
Default X350 Drivers door lock problem
Hi, Getting very frustrated with my drivers door lock. Operates fine off the key, locks and unlocks fine from inside, yet i put it into gear and the doors lock then it locks me in. The only way i can unlock after this is by using the fob or pulling the other door handles from inside as you would to normally open the car. I have replaced the inside door handle as the old one had broken previous to this but this fault just hangs around. could the problem be in the door lock mechanism? Ive had it apart a few times and all looks fine but is there any adjustment that needs doing? all the other doors work fine.
Old Nov 11, 2020 | 02:44 PM
Simon 63's Avatar
I have the exact same fault. If I ever get to the bottom of it I'll let you know.
Old Nov 12, 2020 | 03:29 PM
meirion1's Avatar
There is no adjustment
The driver's door lock is different to the others since it has four switches in addition the
microswitch which operates the door.
The passenger has two and the rear none.
These switches are the slider type where a contact wipes a track and these can wear out
until there is no contact.
I can only imagine that this is the root cause hence you could try replacing the lock but it will not be cheap.
NB it's only an educated guess on my part.
Simon 63
Nov 15, 2020 03:36 PM
vbsummers1
Feb 18, 2018 08:40 AM
TinRoofRusted
Dec 30, 2014 04:34 AM
OSK_Gomer
Dec 19, 2014 07:02 PM
MAC93XJ6VP
XJ40 ( XJ81 )
Jan 7, 2011 04:47 AM
