X358 front susp de-klunking project
Happy New Year everyone!!
I will post more details on this thread but am having a celebratory drink (ok 3!) after re-doing driver side upper A-arm and outer tie rod. Did pass side Christmas wknd.
Both adventures took about 4 hours and I felt trashed afterwards, but road feel is 80% less klunky!!! I have new sway bar bushes but need to recover before that project
My biggest bitch...if these are wear parts, why the **** do they make the upper A arm nuts near the firewall so Ffffff'ing hard to access.
But lots of swearing and "Job done!"
If you are plannung this project, PM me for lots of advice!!
Randy
Randy
I feel for you! Those dang bolts on the upper A arms on the drivers side are a SOB to work on.
Glad you got it as some instructions say to remove the brake/master cylinder stuff which you do NOT want to do if possible.
the job is so easy it shouldn’t take more than 20 minutes a side once you get the wheels off
Xalty...you must know other secrets! I had rachet wrenches, extenders, swivels...there is just too many AC pipes, black plastic bullshshit pipes, wiper fluid resevoirs...
I know now why my British guy charges 4 hours at $185 because he takes all the shrouds, covers, etc off so a simple ratchet wrench works!!
before that all you need is an electric ratchet with a hand finish
yes remove the top nuts and swing the air spring in the direction you need to slide the bolt out
The upper arm firewall bolts, as well as the fronts on both the 04, & 07.
Were accomplished by using the flex ratchet wrenches.
Never thought about taking the upper shock bolts out then pivoting them
exiledbrit
May 5, 2023 02:28 AM
exiledbrit
May 31, 2019 01:44 PM
