XJ8, slow to start
Old Jun 26, 2018 | 08:21 AM
rprivers's Avatar
Default XJ8, slow to start
2007, XJ8, 62K miles, naturally aspirated
My car is slow to start, need to crank several times before firing up. It does not always do it so seems like plugs may not be the problem. I keep Stabil in fuel but try to start it and drive a little every 2-3 weeks if it isn’t used.
It has original plugs and I have never cleaned the injectors. Coils are original.
I plan to take the plugs out anyway so they don’t seized in the threads. I guess then get injectors cleaned.
Any suggestions would be great.
Old Jun 26, 2018 | 10:27 AM
Welcome to the forum rprivers,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Old Jun 26, 2018 | 12:34 PM
mhamilton's Avatar
Next time turn the ignition to position II for 3-5 seconds before you crank it. This will prime the fuel system. If it starts easily when you do this, it is most likely a leaking check valve at the fuel pump. Been seen by a few others here on the forum, mostly shows up as long crank times in cold weather.
It is possible it is a leaking injector (or some other issue with the fuel pump), but that is less common. If you really want to find out you can determine which side is leaking by using a fuel rail adapter/test kit and see if the fuel bleeds off from the supply line or from the injector side.
Old Jun 28, 2018 | 05:16 PM
rprivers's Avatar
Thanks.. I will try your suggestion. I believe you are correct, it must be fuel related.
Reverend Sam
Nov 10, 2014 01:38 AM
Jag-Nut
Jun 22, 2012 07:46 AM
Reverend Sam
Sep 9, 2011 07:33 PM
zibby_uk
Jul 19, 2011 11:50 AM
zibby_uk
Jul 18, 2011 11:12 AM
