XJR Walnut burl
Old Jan 8, 2018 | 11:40 AM
Jcruisn's Avatar
Default XJR Walnut burl
2006 XJR --- Can someone tell me definitively if wood trim is real, a veneer, plastic?
Old Jan 8, 2018 | 03:51 PM
Fraser Mitchell's Avatar
It is real wood veneer.
Even Bentley and Roll-Royce cars use veneer, even though it may be glued on top of another piece of wood. However most wood veneer is now glued onto metal panels.
For older cars like the 1960s saloons the dash panels were made up from 1/2" plywood, then veneered on top. If you take the wood in a Mark 2, (all 26 pieces of it, only a very few pieces are genuine hardwood without any veneering.
In the 70s (or it may have been the 80s), a glue was developed that allowed wood veneer to be glued onto a metal base. My Rover 75 had a genuine walnut veneer dash, with a few pieces of very convincing "walnut" below it. Later on greed came to the fore with Rover management and the veneer part became plastic.
Old Jan 8, 2018 | 05:22 PM
Dan R's Avatar
nationalforest.org | Business Success Stories - Jaguar Cars Ltd
Link to Jaguar sponsored English walnut forest.
Old Jan 9, 2018 | 04:11 PM
JagsteRJX's Avatar
Looks more like the faux wood plastic in my dad's old 80s Toyota T18, than the wood in his Mark 2.
Old Jan 9, 2018 | 05:32 PM
All the wood trim parts in the 60s Jaguar saloons was produced at their main factory at Browns Lane in Coventry. Although the later cars had a lot less wood trim, I have seen craftsmen in the "saw mill" inserting white box-wood inserts into the veneered dash panels during a visit in the late-80s to Browns Lane. This box wood was used to give a nice contrasting appearance to the walnut parts.
PS - it was always called the "saw mill" because at one time SS Cars and Jaguar only produced wood-framed bodies to put onto Standard chassis. It was only in the late 30s that steel-bodied cars were produced by Jaguar. The "saw mill" then only produced trim parts.
Old Jan 15, 2018 | 11:24 AM
mberman's Avatar
I believe the steering wheel is simulated wood.
Old Jan 15, 2018 | 04:36 PM
Hmm, I think it is wood, as it is always described in the brochures as "wood-rimmed steering wheel", and if it isn't, they are opening themselves up to a lot of bad publicity and even law suits. My wheel certainly feels cold and "woody". If it were plastic I suspect it would not feel so cold in winter ! On my old Rover 75 only the dash panel was wood the rest of the "wood" trim was plastic, but a really excellent lookalike. I did install the wood-rim wheel on that car too.
I do remember refinishing the 26, (yes, 26) pieces of wood trim in the Mark 2 I rebuilt in the 80s. I actually took a photo of all 26 pieces on a white sheet, but unfortunately this was long ago and I have lost those photos.
Incidentally, some years ago, I went round the Bentley factory here in Crewe and in the trim shop they showed us pieces of wood trim that after production, they couldn't fit because they showed evil faces or suchlike. This happened when the veneers were mirror-matched in production, and it was only noticed once varnish was applied.
Old Jan 30, 2018 | 11:07 PM
Gazoo2's Avatar
That's interesting; my 05 XJR wood trim above the glovebox has an image in the book matched wood that quite clearly looks like a skull. I think it's very nifty.
Old Jan 31, 2018 | 04:18 PM
When I had a tour of Bentley Motors a few years ago, they showed us pieces of trim like that. They are pulled out of production use before they potentially upset the new owner.
tommyd
Jun 30, 2015 09:19 AM
tommyd
Apr 11, 2015 03:21 PM
jahummer
Feb 10, 2015 04:08 PM
britishautowood
Dec 14, 2013 04:37 PM
anexsia5
Jul 16, 2012 06:17 PM
