1996 XJ6 won't stay running
Old Mar 27, 2019 | 09:00 PM
Jamespri's Avatar
Default 1996 XJ6 won't stay running
Hi there, so i have a 96 xj6 and have been having issues and it sucks. So i replaced the mass Airflow sensor because when i put it on the computer its not reading it. When i unplug it does nothing. Funny thing is when i take the air intake off the throttle body the car will stay running but if i have it on it won't stay running. I'm lost. I had a mechanic tell me the ecm might be bad but he's not sure. I have no codes. When i do have the intake off i cant rev the motor to quick or it will die. Any help will be appreciated i miss my jag
Old Mar 27, 2019 | 09:04 PM
Jamespri's Avatar
Default Pic
My xj6
Old Mar 28, 2019 | 05:07 AM
Welcome to the forum James,
I've moved your question from General Tech Help to X300 forum. This is the place to post technuical questions about your model.
Old Mar 28, 2019 | 08:33 AM
Lady Penelope's Avatar
When you lose certain sensor inputs to ECU it by design will default to a less then optimal set of data maps , you are not at replacing the ECU
Since the engine is originally today a bit out of wack in one way or another the ECU in doing this finds your weakness
To test the MAF the middle wire on the MAF connector should read 1.2 volts DC at the correct idle speed of X
as you throttle up the engine it should climb to but not at the reference voltage of 5.0 DC
The TPS can be tested in the same way on it's middle wire starting at 0.60 + or - 0.02 volts DC at the idle stop
What you don;t want to see is any bips to 0 volts indicating a bad spot on the TPS wiper arm
This ts very precise and should be read with a digital meter
As you slowly rotate the butterfly open you should see a smooth increase in voltage towards that 5.0 reference
This defaults the ECU back to that mode when it sees 0 volts
since the TPS connector is under the throttle body you can nick the wire insulation as it comes over the fuel rail . The wire color is Y
See page 57 and 16
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
eDITING
Old Mar 28, 2019 | 08:38 AM
Jamespri's Avatar
I will check that out on the sensor. If that is reading that what else could it be. Its weird that it will idle fine with the intake off the throttle body. But wont start with it on.
Old Mar 28, 2019 | 09:16 AM
Check that the TPS connector is on , I found mine was just sitting on there because the locking clip was missing
Vee had the suggestion on twisting the pins / blades on the connector a bit to make better contact
THE MAF for the normally aspirated engine is different then the one for the supercharged engine
Continuing to edit above post
Earnest
Jan 9, 2021 11:32 PM
EZDriver
Apr 10, 2019 07:00 PM
Tcherek
Mar 29, 2019 04:12 AM
Jamespri
Mar 28, 2019 09:13 AM
BrentGardner
Mar 9, 2019 06:34 PM
