1996 xjr - lost power to instrument panel
Old Jun 20, 2023 | 06:11 AM
trevors333's Avatar
Default 1996 xjr - lost power to instrument panel
Hi, I was driving along and heard a loud bang from the front passenger side, and then noticed I had lost power to the dashboard instrument panel. The lights and windows still work but nothing happens when I turn the ignition on.
Any suggestions or ideas what may have blown up? Has the body processor module blown up?
Trevor Smith, Austin, Texas
Old Jun 20, 2023 | 08:30 AM
Parker 7's Avatar
The instrument cluster has 2 or 3 fuses in the left heelboard fuse box
Some but not all fuses in the fuses boxes require the relay in the corner of the fuse box to close
with the key in the run position but engine not started you can remove the relay and feel it click back open in your finger tips
There is a light dimming module you can put in override for full instrument brightness
See page 22 of the Jaguar LWB pdf
X300 1996 LWB.pdf (jagrepair.com)
Old Jun 20, 2023 | 08:50 AM
Parker 7's Avatar
On the front right side near the passenger right foot is a inertia / crash switch that can trip
You can depress the button to reset but does not always reset so you jumper the 2 white wires with a paper clip
This will bring the engine back to life
This is a pic of a right hand steering model as the inertia switch will always be on the far right side
Old Jun 20, 2023 | 10:44 AM
trevors333's Avatar
Thanks, any idea what might have blown up to make the loud bang, I will check what you suggested, thanks again for the response.
Old Jun 20, 2023 | 12:25 PM
Vee's Avatar
Vee
Not that it would cause instrument cluster failure, but when the the exhaust manifold cracks, it will set off a bang! Its on the passengers side of the engine bay...
Old Jun 21, 2023 | 03:24 AM
Spud Maat's Avatar
What do you mean.....
it's on the drivers side...
atleast for those of us with the wheel on the CORRECT side!!!!!!!!!
Old Jun 21, 2023 | 06:04 AM
Parker 7's Avatar
This is a longshot but related to electrical power
Under the car on the left side near the alternator is a noise suppressor that is not found on all X300 models
It is a black vertical cylinder with 2 wires attached to the alternator with a 2 wire connector
Remove at the connector and leave the pigtail wires attached to the alternator least they be reconnected on the alternator wrong
It is a capacitor and when they blow for what ever reason you would know
We used to plug capacitors into the wall plugs in engineering collage for kicks with a bang
marcocomb
Apr 22, 2021 07:18 PM
3kgtjunkie
May 23, 2020 12:43 PM
Colm O
Oct 11, 2018 02:09 AM
J5hort
Jul 3, 2017 03:40 PM
