1997 Jaguar xj6 Central Lock not working
Old Nov 6, 2016 | 01:57 PM
DucatiJosh's Avatar
Default 1997 Jaguar xj6 Central Lock not working
https://youtu.be/qKBhFA_35HM
This is what I found in the trunk any ideas would be wonderful
Old Nov 6, 2016 | 04:36 PM
95Leaper's Avatar
I'd suggest heading to your local salvage yard and get the remaining part of your wiring harness that is missing and start from there. It would make things a whole lot easier.
Old Nov 6, 2016 | 06:14 PM
DucatiJosh's Avatar
I was told it was for the cd changer and a non issue in its state
Old Nov 6, 2016 | 06:18 PM
95Leaper's Avatar
Have you tried programming the remote (key fob) to your system?
Old Nov 6, 2016 | 07:02 PM
DucatiJosh's Avatar
Yes but to no avail
Old Nov 6, 2016 | 07:13 PM
95Leaper's Avatar
Try removing the security fuse in the spare tire well and resetting the system,sometimes this will work. Also disconnecting the battery for a few minutes may help. You may have a bad security module (located just forward of the fuel filler door above the rear wheelwell) or your remote might be a different frequency from the unit. Did it previously work at one time?
Old Nov 6, 2016 | 07:16 PM
DucatiJosh's Avatar
Had the car for 3 weeks never worked for me
Old Nov 6, 2016 | 07:23 PM
95Leaper's Avatar
Make sure your batteries are good in the remote (CR2016). Sometimes the lights will flash but it may still be weak enough not to put out a good signal. Are you familiar with the remote reset procedure?
Old Nov 6, 2016 | 07:39 PM
DucatiJosh's Avatar
Im sorry the alarm in the car has been replaced with an aftermarket unit
