4.0 engine custom air intake setups?
Old May 31, 2018 | 08:48 AM
  #41
Keesh's Avatar
Attached Thumbnails 4.0 engine custom air intake setups?-hpim1132.jpg   4.0 engine custom air intake setups?-hpim1133.jpg   4.0 engine custom air intake setups?-hpim1136.jpg
Old May 31, 2018 | 11:25 AM
  #42
cdma's Avatar
Can you tell me what parts you used. This is very interesting. Some of the parts I would have no idea what they are.
Old May 31, 2018 | 01:56 PM
  #43
Keesh's Avatar
The pipe is polyethylene(HDPE) and the filter housing is of poly vinyl Chloride pipe with a diameter of 160 mm. In a 160 mm end cap a hole made of 115 mm for the pipe. Diameter inlet filter is 115 mm. After the elbow piece go from 115 mm. with fitting to 83 mm.
Old Jun 2, 2018 | 05:45 AM
  #44
dfieldsend's Avatar
Mine is now updated with a piece of aluminium bend instead of the back plastic thing so is as straight as possible.
Old Jun 2, 2018 | 06:57 AM
  #45
Scotlad's Avatar
dfieldsend, wow! that is quite a detailed engine compartment! Do you have more shots of the engine including the cam cover? Is the intake manifold powder coated or polished?
Did you move your electric fans to the other side if the radiator? It took me a minute to notice something was missing since I was looking at all the eye candy. I do not think I have ever seen such an upgraded-detailed engine compartment on a X300, great job!
Old Jun 2, 2018 | 07:54 AM
  #46
dfieldsend's Avatar
Its an oldish pic - the fans are off and so is the other pipe onto the oil catch can (bottom right)
Currently radiator is off as well as I'm fitting a new one with hand made cooler pipes for the gearbox and power steering connections. Once i've finished fitting the custom fuel tank and run the front the back fuel lines, i'll get back to finishing off the engine bay.
(All metal is polished BTW)
Old Mar 22, 2022 | 06:16 AM
  #47
JezuzNoChill's Avatar
I know this is an old post but wouldn't an aluminum intake absorb more engine heat making intake hotter?
BrentGardner
29
Dec 16, 2024 12:13 AM
Woznaldo
Jan 31, 2016 03:22 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
tberg
Sep 7, 2015 07:32 AM
casepie
Aug 30, 2015 09:49 PM
