'95 X300 Trunk/boot lid won't open
Old Oct 1, 2013 | 04:34 PM
Rhett's Avatar
Default '95 X300 Trunk/boot lid won't open
Starting a new thread for this since my symptoms are slightly different.
Anyway, the exterior boot lid push button (cat face) and the internal boot lid release button stopped working sometime between last night and this morning. When I push the buttons, instead of hearing an electronic sound of some kind, there is silence and no response.
I did manage to get the boot open with a spritz of WD40 and a fair bit of wrangling with the key (pushing down on the lid at the same time) so now I'm trying to work the problem.
I'm thinking it's either a fuse, a relay or the wiring. The wiring looks fine from what I can see (there's a lot I can't see so it could still be wiring) but I'm thinking I'd like to check fuses and such first.
My question is: What fuse/location controls the boot lid opener button?
Thanks in advance,
Rhett
Old Oct 1, 2013 | 05:01 PM
theJPster's Avatar
The boot (or 'trunk') switch connects pin CA19-20 on the Security and Locking Control Module to ground.
The SLCM is powered through boot fuse 4 (10A) but if that had gone, I imagine all of the door locks would be dead.
My guess would be a faulty switch. Does the switch on the dash still open the boot?
Old Oct 1, 2013 | 05:09 PM
aholbro1's Avatar
Checkthe wiring at the hinge. Can't remember so you'll have to do a search - left or right side boot hinge is famous for chaffed wiring
Old Oct 1, 2013 | 07:03 PM
Rhett's Avatar
No, it doesn't. That's what I meant by "internal switch". They both worked yesterday, they both *don't* work today.
Old Oct 1, 2013 | 07:40 PM
avioni's Avatar
ive had this same problem since forever and could never find the problem. cheked wiring,fuses can only open with the key.
there was a relay i manually activated and heard the mechanism in the boot work but dont remember if that popped it open or not.
Old Oct 2, 2013 | 07:12 AM
SleekJag12's Avatar
Default Boot Latch Relay
Hey fellas,
Below is the trunk fuse/relay box.
Your boot latch relay is the middle relay, half size, black with purple stripe. Your other relays may be blue. From left to right: Heated rear window, Accessory socket, Boot latch, Fuel pump, High mounted stop lamp. Photo courtesy of Adam.
Chafed/broken wires along right trunk hinge cause all sorts of problems, so check them out.
Old Oct 2, 2013 | 07:15 AM
SleekJag12's Avatar
Also don't be concerned if the accessory socket is empty of relay as in this photo. It usually is.
Old Oct 4, 2013 | 04:47 PM
Rhett's Avatar
Turns out the wires were shorting inside the perfect-looking insulation. Two new wires later and it's all mended.
Thanks!
Old Oct 4, 2013 | 05:03 PM
avioni's Avatar
great you fixed it!. can u say what color wires you replaced?
aholbro1
Dec 29, 2024 06:46 PM
Forcedair1
Feb 19, 2020 01:51 PM
findre
Sep 10, 2015 05:46 PM
280zx-turbo
Sep 10, 2015 06:29 AM
prettydaim
Sep 7, 2015 05:16 PM
