95 xjr trunk fire
Old Apr 2, 2008 | 11:04 PM
JagtechOhio's Avatar
Default RE: 95 xjr trunk fire
No way, you should have another look. Make sure your battery isn't getting really hot after you run your car for a bit. I don't think you found the cause, and that would concern me.
Old Apr 2, 2008 | 11:22 PM
bigdreams05's Avatar
Any loose metal in the back, like a socket or a wrench or something that could've possible sparked as it hit some metal in the car going over a bump on the road? Does what I just said make any sense?
Old Apr 2, 2008 | 11:28 PM
Oh OK, reading your first post gave me no indication as to your skill level. I think the vents you are referring to are for the fresh air extraction system, the cabin pressurizes with the climate control on and cabin air has to escape a closed-up car somewhere. Not the source of a flashpoint for sure.
Absolutely I have not heared of anything like that, and hopefully you will get some additional input. I would be busy playing XJR CSI.
dsnyder586
Dec 29, 2024 07:39 PM
Rivguy
Dec 4, 2020 07:55 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
Bowman
Sep 3, 2015 03:17 PM
