96 XJ6 Fuel Filter Location.....
It's up under the Driverside rear wheel arch. If you get underneath and look up and behind the rear coil spring you will see it. just follow the fuel lines from the tank. It's a bit tight and you will get covered in fuel but it's doable.
MMMM, Drivers side depends on where the driver sits.
Behind the LHR (Left Hand Rear) wheel arch INNER area, just near the LH output shaft.
As said, easily seen from under the car, once raised on ramps etc.
Although I am embarrassed how long it took me to find the fuel filter--more than three months--out of desperation I searched it up on YouTube and got lucky two days ago .
In retro respect, I should I have visited YouTube eons ago...it's always the last place you look...
aholbro1
Dec 29, 2024 06:46 PM
rusty37
Apr 5, 2020 07:40 PM
