96 XJ6 Shakes When Stopped
Old Sep 1, 2008 | 01:37 PM
hatajay's Avatar
Default 96 XJ6 Shakes When Stopped
Hi Guys,
I just bought a 96 Jaguar XJ6, 140K+ miles, and am having a small problem with it.
The car shakes once ever 10-15 sec when stops, and I am not sure what the problem is.
And furthur more, the car engine stopped when I stepped on break yesterday in a shopping mall. Luckily, the car powered right up after 5 seconds later.
Can someone tell me what the problem might be? Thanks for your help in advance.
Frank
Old Sep 1, 2008 | 07:12 PM
harounq21's Avatar
Default RE: 96 XJ6 Shakes When Stopped
I used to have an Acura Integra that used to shake at stop. You need a tune up. Thecoils/spark plug/distributor cap needs to be replaced ASAP.
Old Sep 2, 2008 | 03:40 AM
Brian Felts's Avatar
When doing your tune up I would look real hard for a Vacuum line that is cracked or fallen off. This can cause your motor to go crazy when the throttle shuts quickly.
Brian
Old Sep 2, 2008 | 09:43 AM
jag_genius's Avatar
Probably needs a coil
Old Sep 5, 2008 | 02:18 AM
kraziegreggz's Avatar
.....and you might wanna check the engine mounts/bushings; was told that's the problem on mine, shakes too, but slightly. Haven't done it yet;- I assume its a big job replacing them?? Any experiences???
Harry Dredge
Oct 4, 2024 05:37 PM
1100me
Jul 24, 2023 06:10 PM
rusty37
Apr 5, 2020 07:40 PM
1100me
Sep 7, 2015 06:26 AM
JagLove86
Sep 6, 2015 10:36 PM
