abs light & trac off after replacing pads?
Old Mar 15, 2014 | 01:55 AM
Ericbilt25's Avatar
Default abs light & trac off after replacing pads?
Hello once again. I'm getting ready for a road trip and I came across a big issue with my abs light & trac off when I replaced my rear pads on my 97 XJR. The previous owner topped off the brake reservoir so I had to remove some by siphoning and I was using a c-clamp to press the pistons back. I replaced the pads, didn't disconnect any sensors or nothing, topped off the reservoir with jaguar brake fluid and now my abs light & trac off is on. I reset the ecu with removing the negative terminal from the battery for 15-20 minutes and that didn't help. Any suggestions? The front pads were fresh they didn't need to be touched except for the rears.
Old Mar 15, 2014 | 03:38 AM
Ericbilt25's Avatar
I had to replace my throttle cable and I think my sensor on the traction control got miss-adjusted during the process. I'm looking at this diagram and following directions, but it seems to not be working. I adjusted the wire until the pin contacted the sensor.
File Type: pdf
Old Mar 15, 2014 | 09:26 AM
motorcarman's Avatar
The ABS module will have DTC(s) logged for diagnosis.
I know that no one seems to want to find or pay somebody to read the codes but it speeds up the process of repair.
We can all guess or you can throw parts at it until you get the right one but...............
Find someone with WDS, IDS, PDU etc. would be my suggestion.
bob gauff
Old Mar 15, 2014 | 11:52 AM
Don B's Avatar
Originally Posted by Ericbilt25
Hello once again. I'm getting ready for a road trip and I came across a big issue with my abs light & trac off when I replaced my rear pads on my 97 XJR. I replaced the pads, didn't disconnect any sensors or nothing, topped off the reservoir with jaguar brake fluid and now my abs light & trac off is on. I was using a c-clamp to press the pistons back.
Since both ABS and Traction Control depend on the wheel speed sensors, it would be worth checking for a partially-disconnected rear wheel speed sensor or damage to the wiring of either sensor. Perhaps your C-clamp accidentally pinched the wiring harness and caused a short to ground or an open break.
Also, on ABS-equipped vehicles, it is a good idea when pressing the pistons back to open the bleed nipple to allow dirty fluid to drain into a catch-bottle rather than being pushed back into the brake lines. When finished with the job, top up the master cylinder with fresh fluid from a just-opened bottle (a bottle that has been previously opened and has been sitting on a shelf may have absorbed moisture from the air). Better yet, if it's been a while, flush and bleed the entire brake system with fresh fluid.
Cheers,
Don
BrentGardner
29
Dec 16, 2024 12:13 AM
Jimscriv
Nov 4, 2015 02:18 PM
ronald4313jm
Aug 31, 2015 07:58 AM
Terencex
Aug 26, 2015 08:47 AM
NinoGrimace
Aug 26, 2015 05:15 AM
