Abs sent out for repair, now car acting strange, normal???
Old Apr 4, 2012 | 04:54 PM
daboss085's Avatar
Default Abs sent out for repair, now car acting strange, normal???
Hello.... I removed the abs and sent it out for repair today to BBM, and now with it disconnected the tranny shifts differently, speedomoter does not work, and when turning on headlights, the airbag light comes on. I am guessing that this is all liked because the abs is disconnected? I just wanna make sure! thanks everyone!
Old Apr 5, 2012 | 06:31 AM
Fraser Mitchell's Avatar
Question is should you be driving the car without the ABS ?
Old Apr 5, 2012 | 07:22 AM
Doug's Avatar
Is suspect it's all normal as the ABS and speedo use wheel speed signals....which are are no longer reaching their destination with the missing module essentially opening the circuits. I pulled the ABS fuses once and had similar results.
Old Apr 5, 2012 | 07:26 AM
Doug's Avatar
No worries, AFAIK. Every car that I'm aware of is so designed that the ABS can be inoperative....intentionally or unintentionally... but the "base" brakes still function perfectly normally.
Old Apr 5, 2012 | 08:00 AM
Brutal's Avatar
yeah youll have conventional brakes, but without a speed signal to trans its gonna shift funny. has not referance for road speed and therefor will have incorrect shift points and line pressure. it probobly subs TPS signal, but if I had another car I wouldnt drive it only for the trans shifting issue. Low line pressure and incorrect shift points can be like your foot riding a clutch pedal and slipping
Old Apr 5, 2012 | 08:48 AM
etaent's Avatar
Hey Brutal, any tips on removing the abs module? i tried but i dont see it happening without removing the abs pump on top first.
Old Apr 7, 2012 | 03:24 PM
daboss085's Avatar
ok so the car began to start stalling on me as i was braking. It would loose power as soon as I am about to come to a complete stop... is this related to the abs not being connected?
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Jimscriv
Nov 4, 2015 02:18 PM
smokin_hobo
Aug 29, 2015 12:13 AM
Terencex
Aug 26, 2015 08:47 AM
