Airbag Control module thermal fuse
Old Dec 3, 2023 | 09:50 PM
IanMat's Avatar
Default Airbag Control module thermal fuse
Hi all , I have traced an SRS Airbag warning light fault to the Thermal fuse open circuit which is marked as F1 inside the module. Can anyone inform me of a supplier for this fuse or information on its type / size / rating etc to allow me to renew it rather than buying a complete replacement module. I will try to post pictures , fingers crossed 🤞 Tks Ian
Old Dec 4, 2023 | 01:08 AM
Jagsandmgs's Avatar
NTE8167
Old Dec 4, 2023 | 11:10 AM
Parker 7's Avatar
SK948 appears to be a equivalent to the NTE8167
They can be found on Ebay , Amazon and such
15 A, 277 V, 170 °C
Old Dec 4, 2023 | 03:59 PM
IanMat's Avatar
Thanks Parker7.
Great info much appreciated.
Ian
Old Dec 4, 2023 | 04:39 PM
Parker 7's Avatar
NTE8167 datasheet(1/1 Pages) NTE | Thermal Cutoff (alldatasheet.com)
See note 3 at the bottom.
Old Dec 4, 2023 | 04:51 PM
IanMat's Avatar
Thanks again mate , great to have all this knowledge available. Regards Ian
Old Dec 4, 2023 | 05:24 PM
b1mcp's Avatar
The Thermal fuse blows as a fail safe self destruct mechanism when the control module detects a short to ground on one of the trigger circuits - Crash Sensor or Safing Sensor (from memory)
Make sure you have tested and eliminated any faults before replacing the fuse / control module - or the fuse will blow immediately and back to square one.
Old Dec 4, 2023 | 05:41 PM
Parker 7's Avatar
A fuse sometimes can not be tested with a meter as it is still installed least a sneek circuit path in the circuit board
Brendan , is the 15 amp correct for this Jaguar / Ford unit ?
You can clip off the blown fuse barrel leads and use this WAGO brand lever clamping butt splice in your trouble shooting if the soldiering point is tricky
Ask me if they are neat fidget toys
Old Dec 5, 2023 | 05:01 AM
IanMat's Avatar
Yes mate thanks so much for your input.
Got that onboard.
Regards,
Ian
Old Dec 6, 2023 | 09:16 AM
Parker 7's Avatar
Thermal Cutoffs (Thermal Fuses) | Electronic Components Distributor DigiKey
Snackalac
Nov 16, 2022 08:02 AM
cooperd
Dec 16, 2018 03:54 PM
Timsjag
Feb 9, 2018 10:07 AM
ajpds
Apr 21, 2015 03:44 PM
rhofatl
Jan 21, 2015 06:29 AM
