Ambient sensor reading
Old Jun 21, 2019 | 06:03 PM
cdma's Avatar
Default Ambient sensor reading
I was looking at the outdoor temp and it was about 20 degrees off. Does that mean I need to replace the sensor or is there something I am missing. I am not sure if I kept it off my parts care if that is what it is.
Old Jun 21, 2019 | 07:43 PM
Lady Penelope's Avatar
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
Old Jun 21, 2019 | 08:19 PM
katar83's Avatar
Nah, it means that the plug under left wheel arch liner at the front is corroded. Remove the liner around the bumper and you'll see a large plug/socket. Clean each pin hole with a 1mm drill and the pings with some contact cleaner and it will show correct temp again.
Old Jun 24, 2019 | 07:04 PM
cdma's Avatar
That was it. All working
Krisfx
Jan 18, 2022 06:07 AM
yachtmanbuttson
Sep 8, 2018 12:23 PM
Pete Type X
May 14, 2018 05:35 PM
mjlaris
Oct 15, 2012 03:34 PM
ThomasElliott
May 1, 2008 06:15 PM
