Blower speed
Old Mar 14, 2013 | 08:06 PM
auto666's Avatar
Question Blower speed
Hi Thanks for having this forum
I have a 1997 xj6 vanden plas and the blower speed
slows down sometimes when i take off
and then speeds back up when i come to a stop any suggestions?
Old Mar 14, 2013 | 08:39 PM
sogood's Avatar
My 96 Sovereign does the same thing.I keep meaning to look in the owners handbook to see if it's an actual "feature" which I suspect it is. It makes some sort of sense, that if you slow down, you dont have the natural flow through of air, so the blower compensates, and vice versa when you accelerate. Just my thoughts.
Old Mar 14, 2013 | 08:54 PM
Doug's Avatar
Same here.
Blower speed is indeed road speed sensitive (so are the wipers although I've never seen any difference....must be very subtle).
On my car this feature is not active 100% of the time. There might be some system logic at play that I don't understand and certainly never bothered to research. Seems to me that it is active only if "auto" mode is defeated. Not sure. I haven't given it much thought of late.
Old Mar 14, 2013 | 09:48 PM
auto666's Avatar
Smile
Originally Posted by Doug
Same here.
that was my thought but it slows down too much
Old Mar 15, 2013 | 03:58 AM
Ziggy's Avatar
Give the aspirator/cabin temp sensor a clean - my fan seems to behave rather more as you'd expect now that it's not insulated by a thick layer of dust!
Old Mar 15, 2013 | 09:47 AM
auto666's Avatar
cool thanks can you tell me where the sensor is?
Old Mar 15, 2013 | 10:58 AM
Doug's Avatar
It's mounted in the driver side under-dash trim panel, low and to the left. It's an easy matter to remove the trim panel and then remove the aspirator assembly from the panel
Old Mar 16, 2013 | 06:11 AM
Ziggy's Avatar
Just for completeness' sake - it's low and to the right for RHD cars! Behind the little squarish grill. On Doug's advice, I disassembled mine and gave it a drop of oil on either end of the fan shaft. My reason was to shut up the noise it was making, but I'm not complaining about it working better too!
Old Mar 16, 2013 | 06:26 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
Old Mar 16, 2013 | 11:07 AM
auto666's Avatar
Smile
thanks will do as soon as my hang over is gone
Old Mar 16, 2013 | 11:09 AM
auto666's Avatar
thank you.
Trim panel on the top of the dash or face?
can you post a picture please?
Old Mar 16, 2013 | 11:21 AM
Doug's Avatar
thank you.
Sit in the driver's seat. Observe the trim panel directly in front of your knees, then look a few inches above the hood release handle. You'll see a small opening that looks like a tiny speaker grille. The aspirator is behind the little grille opening.
Old Mar 16, 2013 | 11:44 AM
auto666's Avatar
thank you very much
Old Mar 16, 2013 | 02:44 PM
Have some coffee!!
Old Mar 16, 2013 | 02:55 PM
Doug's Avatar
Have some coffee!!
No, no!
Tomato juice
Poet
Oct 2, 2015 09:00 AM
millertic
Sep 30, 2015 08:11 PM
Doug S
Sep 30, 2015 02:03 AM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
