Blue tooth module
Old Feb 19, 2020 | 01:28 PM
Stu II's Avatar
Default Blue tooth module
I've just bought myself one of these blue tooth modules:
https://www.discountcarstereo.com/a2d-jag97.html
I have a set of installation instructions here:
https://www.discountcarstereo.com/pdf/a2d-jag97.pdf
As I want to retain use of my CD player, I need to follow the installation 3 method, which involves plugging it into the back of the head unit, and "connecting/splicing/taping a wire to a 12V accessory (switched) supply in vehicle." I'm really not much of a handyman and I've never been inside a dashboard before. Will this wiring be easy and obvious?
As ever, any help will be very much appreciated.
Old Feb 20, 2020 | 12:43 AM
SleekJag12's Avatar
I had a look at the instructions and it looks easy enough, since they have already identified a couple of options for a wire to splice into for switched power. And the module simply plugs right inline with the 8-pin connector.
You can find instructions on how to remove the radio in the Stickies section I believe. You start with removal of the ashtray and work forward. Easy does it so your wood veneer stays undamaged.
Seems like a useful and desirable upgrade.
Old Feb 22, 2020 | 09:53 AM
Stu II's Avatar
Thanks for your help. I did the job today. Aside from having to wait half an hour to try the radio code again, there were no problems at all.
Thanks again!
Old Feb 28, 2020 | 03:05 PM
katar83's Avatar
I've bought the same Bluetooth module some time ago and just installed it in the car. Took maybe 10-15 minutes, plugs in straight away and a switched power supply in lower right(?) corner was connected to red wire coming from the module, works perfectly, I've also bought the little remote for it co can control volume and switch tracks on my phone from the steering wheel.
Very happy with results and can highly recommend it.
Old Mar 1, 2020 | 03:53 PM
Ed209's Avatar
I take it you can't make calls using it? Lack of microphone, I'm guessing?
Old Mar 1, 2020 | 04:19 PM
Stu II's Avatar
No, but they do do a module that can:
https://www.discountcarstereo.com/a2diy-jag97.html
Old Mar 1, 2020 | 04:32 PM
Ed209's Avatar
Ah, brilliant!
Old Mar 19, 2020 | 12:20 AM
X300exec's Avatar
I have a Bluetooth fm converter and it does calls and has buttons for skipping tracks and it small and discrete ,10 quid 👌🏻
Old Mar 19, 2020 | 01:20 AM
xalty's Avatar
what i use as well
the tape deck converters aren’t too bad either if you run into interference on the FM band.
Old Mar 19, 2020 | 01:34 AM
X300exec's Avatar
Originally Posted by xalty
what i use as well
had to get rid of that because my phone doesn’t have a headphone socket
Old Mar 19, 2020 | 08:56 AM
katar83's Avatar
But it has USB which works like headphones jack with a short extension adapter.
Old Mar 19, 2020 | 09:37 AM
xalty's Avatar
there’s usb powered bluetooth adapters that go into the tape deck
MrSinatra
Feb 27, 2021 01:23 PM
Isilus
May 5, 2016 03:45 PM
nobodyspecial
Sep 16, 2014 08:09 AM
vdpnyc
Oct 20, 2013 11:34 PM
dinks747
Sep 29, 2013 04:24 AM
