Boot will not open
Old Apr 30, 2015 | 01:44 PM
wills12345's Avatar
Default Boot will not open
Hi all I have a problem I had to take my battery back to halfords now I can not get into the boot to fit the new one I don't have the master key for this car only the valet key is there anyway apart from buying a new key to get into the boot I'm pulling my hair out
Old Apr 30, 2015 | 02:19 PM
RJ237's Avatar
Can you open the drivers door? If so open the bonnet and find the positive post on either side at the fuse boxes. Apply power to one of the posts with a jumper and use the other cable to ground. Then you can open the boot with the switch on the dash.
If you can't open the doors, do a search and you will find instructions on using a hole by the license plate.
Old Apr 30, 2015 | 02:42 PM
wills12345's Avatar
Thank you I can open all the doors so I will give that a go I will be ordering a new key next month
Old Apr 30, 2015 | 03:27 PM
EZDriver's Avatar
Thanks. Nice to know little tie bits like this.
Old Apr 30, 2015 | 03:42 PM
Jagboi64's Avatar
It's fairly easy to get a key, you have a "tibbe" key. See this on how to decode your key: How to read a Tibbe key - XJ40
From there, you can order one off ebay based on the code you can read off the valet key. I believe the difference between the valet key and the master key is the tip, see this photo: https://www.jaguarforums.com/forum/x...wo-keys-99769/ Each has the 8 cuts, but the green headed valet key has a different tip configuration.
North American cars did not have a chip in the key, not sure about UK market cars. I think they do have a chip that needs to be programmed to be used as an ignition key. Should work the doors unprogrammed though.
Old Apr 30, 2015 | 03:46 PM
al_roethlisberger's Avatar
That should be in the forum FAQ if it isn't already
Old May 1, 2015 | 12:22 PM
wills12345's Avatar
Hi well my beautiful x300 4.0 sovereign is up and running again many thanks I will try that with the key advice
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
kactaf
Sep 28, 2015 12:20 PM
findre
Sep 10, 2015 05:46 PM
