CD player question
Old Jan 30, 2018 | 08:23 AM
Scotlad's Avatar
Default CD player question
I am parting out a 96XJ6 and have removed the amplifier and cd changer from the trunk. I would like to remove the cd cartridge but I need to apply 12 volts to a connection to do it. I just cut the cable going into the changer to remove it. Does anyone know what wire to connect?
Old Jan 30, 2018 | 09:04 AM
Lady Penelope's Avatar
From the wiring guide there is only one wire to the CD changer shown so I can't help you and I don't have one myself . But from the from the cut cable you can put a meter on the cut wires still connected to the car and see if you can find power . Then from the wire color go to the pigtail on the CD changer and put power on that color .
Old Jan 30, 2018 | 11:22 AM
Scotlad's Avatar
Thanks, Lady P. but I have removed a lot of parts already including the radio so there is no way to check for power. I guess I will put power to the different cut wires and see which one works, I just need to get the cartridge out.
Old Jan 31, 2018 | 02:10 AM
SleekJag12's Avatar
How about this? Courtesy of Jacob Hankins a few days ago. Too bad you cut the plug off, the CD player only has about a six inch pigtail to this connector. Look for the pigtail behind the trunk panel. Open it up and it will show the wire colors, going to the +12V wires on pins 6 and 7, and the ground on pin 8.
Edit:
Just noticed that this second figure is in that same thread and shows a different pinout of the 8-pin DIN! It doesn't really make sense for the CD player. Let's see if Jacob can clear this up for us.
JWright92
Jul 4, 2021 08:31 AM
Colin G Kennedy
Audio/Visual Electronics
26
Mar 28, 2019 04:15 PM
2004x-type
Apr 30, 2009 09:10 PM
peewee
Aug 30, 2007 11:15 AM
peewee
Aug 17, 2007 02:39 PM
