Charred Spark Plug - Normal?
Old Nov 4, 2010 | 06:52 PM
Vee's Avatar
Vee
Default Charred Spark Plug - Normal?
I just replaced the spark plugs on the AJ16 and I have posted a picture of what it looked like...
The car has 60,000 miles and I'm not sure if the plugs are original or not.
No dielectric grease was used on any of the boots.
Is this normal? I've never seen the ceramic cylinders get charred like this.
Old Nov 4, 2010 | 07:57 PM
Turftech's Avatar
If it's any help, I had the same thing on a few of the plugs that came out of an XJR. I figured it was due to slight pressure leakage around the valve cover combined with high heat. The "hemi" style plug location seems to cause darkening around the plug when they are run for extended periods before changing? I have noticed this darkening on Toyota engines as well that have recessed plugs, so I tend to think it is more or less common. I'm thinking it doesn't take much oil vapour to cause this sort of thing. Since replacing the cover gasket, I have not noticed any further darkening, but it's early days yet.
Just a thought.
Old Nov 4, 2010 | 08:14 PM
jagman96's Avatar
mine looked the same. especially on the white part of the plug. That could be old anti-seize in the threads. I think some people use it
Old Nov 4, 2010 | 08:29 PM
Vee's Avatar
Vee
Thanks.
I use anti-seize and dielectric grease.
Have you guys used the grease at the ends of the coils?
I have to admit, swapping out these plugs is pretty freaking easy. Swapping them out every 30K will hardly be a chore.
Old Nov 4, 2010 | 09:23 PM
motorcarman's Avatar
This needs to be a major sticky due to number of complaints about the corona discharge (I get this after a night of Mexican beer)
Maybe a little salt and lime with the RC12YC would cut down on the problem!!!
bob gauff
File Type: pdf
Old Nov 4, 2010 | 11:34 PM
Mikey's Avatar
Now that was funny!
Me too, by the way.
Old Nov 4, 2010 | 11:35 PM
mailshack's Avatar
Thanks for the reminder Bob.
I remember thinking my plugs were experiencing blow by because of the discoloration...exactly like Vee's photo...until your info set me straight. Thanks!
Old Nov 5, 2010 | 10:13 AM
Vee's Avatar
Vee
Excellent! Thank you so much. I didn't think I'd be able to get a definitive response like that on this subject.
I wonder if that has anything to do with Champion spark plugs being perfectly suited for these engines. Perhaps other plugs allow the blow to reach the tip of the plugs...
Old Nov 5, 2010 | 11:24 AM
Mikey's Avatar
No, almost all plugs do that on almost all engines. The AC Delcos have always done that on my GM products.
Old Nov 5, 2010 | 06:15 PM
Turftech's Avatar
Interesting! Kinda like the collection of debris around an air ioniser. I guess I was somewhat close to the right answer.
Well, I'm off to build up a massive corona discharge!
Old Nov 5, 2010 | 07:07 PM
Oubadah's Avatar
Yes, I had this too - only not as dark.
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
