Code P1313
Old Dec 22, 2008 | 06:46 PM
carter's Avatar
Default Code P1313
The check engine light came in on my 96 Vanden Plas (XJ6). The local parts shop used a scanner that read "misfire in cylinder 2." I changed all the plugs and re-positioned the coil from cylinder 2 to cylinder 1. The parts guy helped me to erase the code, so as to turn the check engine light off. If the light comes on again and the code reads "misfire in cylinder 1" I'll know that the coil needs replacing. However, the scanner also read code P1313 - what does that code mean?
Carter
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
