codes
Old Feb 16, 2013 | 06:06 PM
zeal's Avatar
Default codes
hi i have a 1995 jag xj6 and found a couple of trouble codes would like to know what they are if any one can help p1138, po430,c1095. thank you for your time
Old Feb 16, 2013 | 06:26 PM
Nitronick's Avatar
p1138 - Lack Of Heated Oxygen Sensor Bank 1 Sensor 2 Switches - Sensor Indicates Rich
p0430 - Catalyst System Efficiency Below Threshold Bank 2
c1095 - Hydraulic pump motor - circuit failure
Old Feb 17, 2013 | 07:45 AM
zeal's Avatar
so these are oxygen sensors and catalitic converter codes except for hydralic pump issue ? where is the pump i dont believe my car has one it has powersteering pump any further assistance on repairs if needed would be helpful thank im new to jaguar ownership and would like to he 95 i own all the love it deserves...
Old Feb 17, 2013 | 08:51 AM
steveinfrance's Avatar
The C code is ABS
https://www.jaguarforums.com/forum/x...c-fault-44272/
How did you read it ?
Old Feb 17, 2013 | 12:48 PM
sparkenzap's Avatar
C1095 refers to the ABS pump motor circuit. There are archive references to how to repair the connector on the ABS circuit board, which is a common failure mode. Or, a used module or repair of yours is available from online sources.
Old Feb 17, 2013 | 04:26 PM
zeal's Avatar
thanks for the input i used a innova code scanner to retrieve the codes my car is a 1995 so the codes dont matter for inspection purposes i just wanted to see what codes it would spit out and how to repair them if any were needing repair theres no check engine lights on or anything or abs lights so i will use all input and determine repair methods appreciate all input
Old Feb 17, 2013 | 04:35 PM
sparkenzap's Avatar
Oh...
If you have no CEL or ABS lights, I would reset the codes (so you can tell if you have any new problems), then have a toast to the Kitty!
Old Feb 18, 2013 | 06:08 PM
zeal's Avatar
thanks for the input erased codes now ill wait and see...i think i may clean wheel sensors at some point anyway and hopefully i wont have to go through pump circuits. thanks again for input
Old Feb 20, 2013 | 02:40 AM
Let us know how you get on - it helps others.
Many folk 'of a nervous disposition' have successfully repaired the pump circuit.
If the fault is intermittent and occurs on turning it could be a broken wire harness - again dozens of posts here.
Old Feb 23, 2013 | 08:34 PM
zeal's Avatar
have not gone any further no lights on dash and recently did rear wheelbearing so maybe the sensor was giving code after having all apart reset codes and have not re-scanned probably gonna do front brake pads soon and will go from there couple other things i would like to do as well nothing really affecting operation runs, stops, goes, so alls well at the moment thanks
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
