condenser bushings
Old Feb 10, 2014 | 03:48 PM
OWRltd's Avatar
Default condenser bushings
After searching threads, I understand that CBC1448 is a mount. But, I also see MNA4250AA or AB as another mount. What gives?
Rockauto has the CBC cheap. Don't I also need the MNA mount? Assuming a dealer item.
Old Feb 10, 2014 | 04:14 PM
vandenplas408's Avatar
Autohausaz.con
Old Feb 10, 2014 | 08:48 PM
AllanG's Avatar
They are grommets.
You will need 2 of the CBC1448 for the top of the condenser and 2 of the MNA4250AB for the bottom.
Condenser and Receiver Drier-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Classic Parts UK
Old Feb 11, 2014 | 06:12 AM
OWRltd's Avatar
Thanks, parts ordered. I'll assume that installation is performed by removing the grille.
Old Feb 11, 2014 | 08:13 AM
aholbro1's Avatar
Probably also have to pull the top cover - 8 or 10 Torx screws in the engine bay, up front near the hood hinges. You may want to replace your radiator iso-mounts while you are at it. (4 pcs, all the same p/n, I believe Rock has them)
A second person is handy, though not necessary for re-assembly. Nice to have someone up front guiding the condenser upper pins into the grommet as you lower the panel back into place - it can be a bit fiddly fitting it over new radiator iso's.
TreVoRTasmin
Feb 23, 2021 03:13 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
Dave1109971
Oct 2, 2015 06:11 PM
