Condenser and radiator mounting bushings
Old Nov 3, 2015 | 08:50 AM
RFXJ12's Avatar
Default Condenser and radiator mounting bushings
Like most X300s my 97 XJ6 needs new bushings installed for the radiator and A/C condenser.
I plan on replacing the lower support bracket for both as well because mine is quite rusted. Really the only rust on the car.
I have located the radiator bushings which the four appear to be the same on the upper and lower.
My question is with the condenser. I'm having trouble locating the correct mounting bushings for this car. Are the upper an lower the same on the condenser or are the two parts different?
Any exploded parts diagrams I can refer to?
Old Nov 3, 2015 | 09:55 AM
dagny747's Avatar
Old Nov 3, 2015 | 09:57 AM
aholbro1's Avatar
Upper & lower condenser bushes are different. Uppers available at Rock Auto for cheap.
Lowers: Dealer is only reliable source I've found and they are normally special-order at that! Not to mention $10+/ea or thereabouts
There are several threads in here calling out the part numbers, if I run across one i'll post a link.
Just saw Dagny's response after I posted - thought he had the answer...... but that's confusing as hell!
Item 2 points to the upper, but then you have to click "lower" to expand to the part number.... of the "upper"
CBC1448 is the correct part number for the upper condenser bush!
I believe MNA4250AB is correct for the lower bush as shown.
Old Nov 3, 2015 | 11:15 AM
RJ237's Avatar
I bought the lower condenser bushes at Coventry West. $11.25 ea a couple of years ago.
Old Nov 5, 2015 | 10:09 AM
RFXJ12's Avatar
Ordered up the parts. Thanks for the resources!
61_mk2
Oct 28, 2015 04:56 PM
Daim
Oct 27, 2015 10:16 AM
Jagzzz
Oct 26, 2015 11:46 AM
280zx-turbo
Oct 21, 2015 05:22 AM
Marty Jackson
Oct 16, 2015 03:21 PM
