Cooling fan replacement.
Old 01-04-2022, 12:50 PM
Jan Christian's Avatar
Default Cooling fan replacement.
Gentlemen. One of the cooling fans has a bearing that is on its way out. Can I replace just that one fan or do I have to replace the whole fan pack? Thank you for any replies..!
Old 01-04-2022, 01:52 PM
Parker 7's Avatar
You can replace the single fan but the whole assembly pulls straight up to come out and worked on as easier , no coolant draining needed as the radiator remains
Do not pull the plastic fan motor connector release too far out as they will break
To test the fan there is a 3 wire connector on the aft lower left radiator and a paper clip from one white wire in the connector to the blaclk wire will give you single fan
Remove clip and the other white wire to that black will give you both fans
This with the key in the run position and engine not started
This is a low current section of the fan control circuit so no arcing hazard
Sure it is the fan and not water pump or alternator ? You can remove both fan connectors and give it a try
You can put the handle of a long screwdriver up to and pressed against your ear and use it as a stethoscope to locate noise , place the tip on the fan motor
Same thing works with a very long socket wrench extension
But you have to be very careful with your hair
Old 01-04-2022, 05:23 PM
Parker 7. Thank you so much for your elaborate reply..! Excellent directions also..! Good news about having to change only one fan instead of the whole thing. It’s the one one top, it is wiggly and squeaks before the engine ignites. On a side note: I once tried to locate a faulty spark plug on a 69 gtx with my hoodie on, laces pointing down at the running fan for a brief unsuspecting moment. That won’t happen again. Again, thank you for your reply, much appreciated..!!!
Parker 7 (01-04-2022)
Svalbard
02-27-2021 11:13 AM
v1rok
07-01-2018 10:02 PM
Rhett
10-23-2015 03:25 AM
vincent661983
07-08-2014 06:10 AM
Quick Reply: Cooling fan replacement.
