Differential removal
Old Mar 25, 2021 | 01:00 PM
mh.anthony6's Avatar
Default Differential removal
So i have some clicking coming from my diff and i am looking for the easiest way to take it out and what special tools im gonna need? Its a 97 vdp.
Old Mar 25, 2021 | 03:35 PM
Parker 2's Avatar
There is a TSB or something on drilling off the bearing retainer from I think the X308 , Do you have it ?
the bolts that you remove on the X is different then the standard Torque Bit
Old Mar 25, 2021 | 04:02 PM
katar83's Avatar
What do you mean by clicking from diff? I cant think of anything that would 'click' in there. Plenty things that could at the back though.
Removing diff is relatively easy and best 'special tool' is going to be a second pair of hands to hold the awkward and heavy bits.
1. Take the A-frame side brackets off
2. With the diff slightly down, you'll now have access to bolts holding diff struts to aframe(next to big aframe bush). They are probably worst thing to remove, easier if you have flexible ratchet wrench.
3. Remove calipers
4. Remove big nuts holding up hubs and bottom fulcrum bolts
5. Remove a-frame(4 bolts at the bottom and 4 at the front) and springs with shocks
6. Undo wishbone tie off the diff and wishbones and remove both wishbones with the tie together.
7. Undo rear diff struts, that the last thing holding it up to the back
8. Undo propshaft at jurid coupling and it will drop down.
While there, I highly recommend replacing shocks and springs, replace wishbone tie with the one with extra brackets for rear anti roll bar and replace rear individual diff struts with X308 differential monobrace. Obviously replace all suspect bushes, change diff oil and jurid coupling, fulcrum bearings and check all u-joints.
Old Mar 25, 2021 | 04:16 PM
I don’t have it...
Old Mar 25, 2021 | 05:17 PM
Parker 2's Avatar
X308 differential monobrace , not hard to remove from donor X308
http://www.jagrepair.com/images/TSB/...usp%20tool.pdf
You can make your own tool to suck the old bushing out​​
Clean differential case breather port
Looking for Bearing retainer drill holes and split with a chisel TSB
Old Mar 25, 2021 | 05:33 PM
Heres how it sounds inside the car while driving and outside in drive while jacked up
Old Mar 25, 2021 | 05:37 PM
3. Remove calipers
Any visuals for this ?
Old Mar 25, 2021 | 06:36 PM
Parker 2's Avatar
There is a photo album on a different website
Old Mar 25, 2021 | 07:37 PM
Parker 2's Avatar
It's in here somewhere
Welcome to Jag-lovers - The Members' Photo Album
Old Mar 26, 2021 | 12:38 AM
xalty's Avatar
just drop the whole suspension assembly, takes 30 minutes. when you have it on the ground it's pretty self explanatory
your problem could be coming from the output shafts, the kit is like 60 bucks a side.https://www.sngbarratt.com/English/#...put%20shaft%60
Old Mar 26, 2021 | 05:18 AM
Parker 2's Avatar
That is the specific kit for the specific target of the output shafts
Hopefully the bearing item is of high quality
Old Mar 26, 2021 | 08:28 AM
Larry Louton's Avatar
The u-joints have grease fittings. I would grease those first and road test before removing differential. Greasing the splines at the outer hubs can eliminate noises also.
Larry Louton
Old Mar 27, 2021 | 06:49 AM
countyjag's Avatar
110% agree with Larry. With the mileage shown on your car, I would very much doubt the diff has a problem, unless there is oil everywhere at your back end. The U Js on the halfshafts on the other hand are often neglected, and are fairly easily greased. Most definitely your first move.
Old Mar 28, 2021 | 10:07 AM
Will be greasing the fitting tonight after work. Still don’t see any reason the rear passenger sits lower than the rest of the car.
Old Apr 17, 2021 | 05:58 PM
Default Update
After some work travel i have greased all fittings with no change. Im gonna try to make some time to drop the suspension and see whats going on
Jackson Frost
Dec 17, 2020 08:57 AM
willyrwalker
Apr 12, 2017 08:16 AM
Shadow993
Dec 21, 2016 08:09 AM
parwun
Nov 6, 2014 03:54 AM
