Don't do this ........or this will happen .
Old Jul 5, 2018 | 09:40 PM
Lady Penelope's Avatar
Default Don't do this ........or this will happen .
Just replaced solenoid unit on starter . After installing on car it shows the same fault . Removed starter assembly again from engine as I should have tested this bad ground path ( spins fine though on bench ) . With the pigtail wire removed that powers through the brushes which goes through the windings to case ground , There is still a solid ground to case from that lower terminal lug to case . This while not energizing the solenoid .
In the big picture this causes the battery cables to drop to 9.5 volt , not enough voltage to properly run the ECU .
I'm I missing something or is this solenoid bad out of stock ? Double check requested .
GregW
Feb 10, 2018 02:22 AM
Humy
Apr 23, 2013 05:25 PM
dominus
Jun 18, 2012 10:30 AM
