Driver seat rails X300
Old Dec 20, 2019 | 02:38 AM
chris hack's Avatar
Default Driver seat rails X300
Having a bit of time over the Christmas period I decided to look at a Drivers seat problem which arose a couple of years back. The fore/aft system would move the seat about an inch then jam.
I concluded there was probably some foreign object in the system and took the seat out of the car.
It seems though that the mechanism which drives the seat has gone out of sequence.
Looking at the rails - now visible - I can see the left one is about one inch further in than the right one.
I compared this to the pax seat and noted the rails on the pax seat were equal.
I believe I need to reset the rails.
Does anybody have any experience of detaching the drive motor mechanism from the rails?
I need to perhaps open the drive gear box but can not see how to do that.
There appears to be a long bolt passing through the gear box which attaches the gear box to the rail.
I can not see how to open this unit.
If I remove the drive motor this does not seem to give access to the drive gear.
Any advice greatly appreciated.
Chris
Old Dec 20, 2019 | 04:50 AM
SteveSheldon's Avatar
Hi Chris,
I have had two X308's and have not seen or heard of this issue before.. so I am not of much help, but if you repost this in the X300 series section you will find people with far more knowledge than me of the X300 series..
The area for this would be https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/
I hope you manage to resolve the issue, and please let me know how you get on, as if needed I do have a couple of external sources that we can tap into if need be :-)
Old Dec 20, 2019 | 05:10 AM
Chris,
I thought I'd read this earlier posted in X300 forum but clearly I wasn't paying attention. I've now moved it from UK & Eire Region to X300 forum for advice from members with the same model.
Old Dec 20, 2019 | 11:39 AM
chris hack's Avatar
In my attempt to resolve the problem I (foolishly) thought to remove the seat base as this would give me better access to the runners and gear motors.
Unfortunately this is not the case.
The drive cables for the backrest pass through the seat chassis and I can not separate the base from the seat.
I thought of remove the cover to the gear drives but this has a long bolt which is fitted aft to fore and the drive mechanism does not permit the removal.
The only way I can think to access the gear drive is cut this bolt and replace in the opposite direction - from front to rear (where there would be sufficient space to refit the bolt.
This seems a bit extreme.
Does anybody know what the powered 'control' is which is attached to the left gearbox drive? There is no such unit on the right rail.
Bit frustrating!
ANy suggestion greatly appreciated.
Best, chris
Old Dec 21, 2019 | 02:04 AM
chris hack's Avatar
I managed to disassemble the seat and remove the offending rail.
This required the removal of all wiring (that which I could)
Then I drilled out the two pop rivets holding the rail to the subframe.
Took the drive unit apart and found the drive wheel has broken up.
Now to find a replacement!
Have some photos but I do not seem to be able to add these to the post.
How do I add a photo?
Old Jan 16, 2020 | 12:43 PM
bollerwagon's Avatar
I seem to have the same issue, the seat is only moving a bit, sometimes a few cm, sometimes not even that. I think I read somewhere, that this happens due to defective seat position sensors (I have memory seats), but that´s just hear say.
Did you succeed fixing it?
Old Jan 16, 2020 | 10:49 PM
chris hack's Avatar
Yes, I found a solution.
The drive gear wheel had broken up.
I purchased a second hand seat base (cost GBP17) and sent this to my brother in the UK.
He kindly removed the gear box by drilling out the two rivets holding the seat rail to the seat base.
This permits the removal of the rail and the gear drive. He sent same to me.
Awaiting receipt and hoping this works.
Sending the seat base to South Africa from UK was deemed 'Too expensive' thus the dismantling.
JagSlave
Jul 10, 2019 09:16 PM
Barin998
Nov 27, 2017 11:26 AM
biffta
Jul 31, 2014 05:07 AM
haroldpeacocksr
Dec 1, 2013 06:33 PM
kandA
Apr 28, 2009 03:22 AM
