Driver seat won't go aft
Old Jan 26, 2018 | 05:18 PM
mcart5's Avatar
Default Driver seat won't go aft
Hi Everyone, My 95 XJ6 VP driver seat won't go aft, only forward with all the other functions working as well as memory. Can someone direct me to a troubleshooting guide for this malfunction. I have seen a tech article on the potentiometers but I don't know if this where I should start.
THX
Keith
Old Jan 26, 2018 | 06:02 PM
Lady Penelope's Avatar
With the suspect motor only going one way that would point to the polarity switching relay inside the module as I believe the potentiometers are used in the memory function and maybe as a electrical stop vs. a hard mechanical stop . Might be able to drive the suspect motor with a fresh 9 volt battery ( ? ) or a battery charger . SM1 - 7D ( Purple / Orange wire ) to SM1 - 8D ( Purple / Slate wire ) for the module connector . Pins marked in purple on pic below :
Can you look under the seat and see if you have a set of relays facing you or a modual that may be able to swap as there are different versions of seats with different wiring
For the 95 X300 the wiring guide can be found here figure 14.1 :
http://www.jagrepair.com/images/Auto.../jagxj1995.pdf
Old Jan 27, 2018 | 12:26 AM
AL NZ's Avatar
I have the same trouble with my Daimler.
The two solutions for my car are:-
1. Slide the seat the whole way forward then repeatedly try to slide it back until it finally does (risky, if it gets stuck you can’t get in unless 4’2”)
2. Push the button inwards against the seat as hard as you can while also sliding the button back. This works if you hold your mouth right and channel the inner Fonz...
Once sorted don’t let someone shorter drive your Jag!
Old Jan 27, 2018 | 12:33 AM
Have you considered removing the switch park , pulling apart , and cleaning as a leather cleaner may have migrated in making bad contacts ?
Old Jan 27, 2018 | 09:04 AM
aholbro1's Avatar
My name is aholbro1 and I'm a seat-don't-go-aft addict as well.....
In my case, the driver's seat module is unresponsive to WDS. Otherwise, exactly as described above - full range of motion with everything working in all directions with the exception of aft-traverse - though as AL NZ notes, that function is intermittent. For now, a useful fault as my youngest daughter is still undergoing driver training, is short, so is handy reason we can't do any training in my car...."I'd never be able to drive it after you adjust the seat..."
I did grab a passenger seat module on my last pick-n-pull visit. Hopefully the same, but haven't done the research, as yet to confirm or deny. Driver's seat module was either gone or inaccessible, don't remember which.
I did pull the fuses prior to my most recent state inspection so as to preclude the possibility of an inspector rendering the car unusable - RH heelboard if you need to do likewise, sorry, don't recall the fuse $ offhand.
Old Jan 28, 2018 | 04:40 PM
mcart5's Avatar
THX all, Looking under the seat is the module facing me, no relays. I think the best way is to pull the module and charge the circuit to see if it is working. Will give it a shot next week. I won't go forward again as I would need to go on a severe diet to get in.
mcart5
Khello
Jan 4, 2024 01:21 PM
MK2
Dec 20, 2019 10:09 PM
Dan R
Nov 3, 2017 11:09 AM
al_roethlisberger
Aug 13, 2017 12:39 PM
Jag_626
Jan 16, 2012 07:44 AM
