dropped front bank
Hello everyone
I have a 96 VDP with 170K miles and it started missing bad, had to have it towed home, it appears the front bank is not firing, as the plugs get wet with gas. it will start and idle but only on the back 3 cylinders, I had put 6 new coils in the car a month earlier. So I assumed the new coils had fried the ECU. so I got another ECU, put some older original coils back in. same thing the front 3 cylinders are not working, I can disconnect the coils while running and it makes no difference. So, I know it may have taken out the 02 sensors, but it should still run, as it is getting gas ( the plugs are wet ) so even if the 02 sensors were shot, wouldn't the ECU shut down the injectors not the spark?
Thank you for your help
Darryl
Darryl
Hi barchettaboy,
Your symptoms sound a lot like the ones dealt with in one of the longest forum threads in the history of forums:
X300 Mystery
Post 623 (out of 644!) suggests your first suspect may be the crankshaft position sensor (CKPS).
Cheers,
Don
X300 Mystery
Cheers,
Don
Hello everyone
Darryl
Darryl
Have you checked the wiring going to the coils to make sure they're getting a signal? If they are then you've got a few bad injectors. I'd work from that point back. It could also be a bad connection/corrosion at the ECM connection.
I did swap out a CKPS ( used ) that I had it did not help.
I did go look at the link you sent Don, that has to be the longest ( like you said ) but also the most depressing post I have ever seen. After what looked like a couple of years, the poster had a major bought of depression and had to quit on the car and eventually scrapped the car. That does not bowed well.
Like I said, I did replace the ECU which looked great ( no corrosion ) I have not checked to see if the front coils are getting 12 volts yet or checked the crank wheel.
I will let you know, but to be honest after reading that other post, I do not want to focus too much on this car, Luckily I have other Jags to use, and I did not pay much for it. I would hate to scrap it out, as it is a fairly nice car. But I am not going to let it break me.
I have customers cars that I need to be working on, that pay money ( Dino, Bentley and Lotus )
Darryl
Darryl
Here's something you may want to look into.....I remembered reading something about the harmonic balancer slipping??? Maybe this could be the cause of your issue? I'm sure there are posts somewhere within the forum.
But it would still be worth ruling out. The most common symptom of harmonic balancer failure is a loud screeching sound at start up or sudden engine acceleration which prompts the outer part of the damper to slip in relationship to the inner part, causing a noise something like a loud slipping belt.
Have you had any symptoms like that, Darryl?
Cheers,
Don
I know all to well about failing harmonics, as some of you may remember, I also have an 95 XJR that had a long standing no start issue. That car stumped me for ( I am embarrassed to to admit 3-4 years ) What I found was the crank key had sheared and spun the harmonic balancer 100 degrees. What I also found when I took it off, was ( you are correct Don ) that the timing wheel is connected to the internal part of the balancer, that is keyed to the crank, so even if the rubber fails and spins it will not effect the timing. However mine had failed and a previous owner had welded the timing gear to the outer part of the damper because it was slipping. Which maybe would kinda work, but on the supercharged car especially, there is a hell of a load of that crank key, so it sheared that baby good. I will say that the key if very undersized for the load that is put on it on the XJR. I am suprized that there are not a lot more failers on the supercharged cars with the wimpy keys they used.
Darryl
Darryl
