EGR Valve...
Old Sep 17, 2008 | 01:07 AM
commercialcobb's Avatar
Default EGR Valve...
I am wondering if there is a correct or incorrect method of cleaning the EGR valve... I got fault code p0400 and p0411 so I know that it is faulty but could just be clogged and stuck open or closed.. Will carb cleaner damage the components of the EGR valve?? I was thinking of using some carb cleaner and an old fashion pipe cleaner to remove the carbon build-up and also clean the lines and ports the are utilized by the EGR valve and its components.. Can I clean this without destroying it??
Old Oct 7, 2008 | 08:39 AM
cool's Avatar
Default RE: EGR Valve...
yes a carbcleaner will do the job.
Old Oct 14, 2008 | 08:53 PM
oldmots's Avatar
You can't hurt the EGR valve with chemicals short of concentrated acid. Its pintleis very resistant to most anything since it handles exhaust gases which are corrosive and contaminated. Use something strong to get the baked on depsoits off of it. I also use carb or throttle body cleaner.
Old Oct 28, 2008 | 07:15 PM
getaway6819's Avatar
Those codes could also have to do with the air pump and tubing joints leaking from manifold to egr and air pump make sure they are tight and not leaking. I changed the air pump and the codes were gone on the XJR
Mike OConnor
89 XJS, 95 VDP, 97 XJR, 99 Deville
mhamilton
67
Apr 1, 2021 03:20 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
shootingbrake
Sep 23, 2015 10:54 AM
