Electric seat moves but not when using memory
Old May 13, 2008 | 07:39 PM
rparker's Avatar
Default Electric seat moves but not when using memory
Hi all,
Just picked up my 1996 XJR and tried to program the driver seat position into memory. The programming seemed to work fine, I got the light on the Memory switch and a beep after pressing the number 1, but then when we put my wife's seat position into memory 2, the seat won't move back to memory 1 position when requested. The mirrors, headrest and steering wheel all move, just not the forward/backward motion of the seat.
I see talk of potentiometers being the culprit, is there an easy way to diagnose and fix this problem?
Cheers,
Richard
Old May 14, 2008 | 09:07 PM
jag_genius's Avatar
Default RE: Electric seat moves but not when using memory
not really an easy way.. need a wiring diagram and a volt meter..
Old May 15, 2008 | 10:09 AM
rparker's Avatar
I have a voltmeter, but no wiring diagram. Can anyone help?!
I guess if it's a potentiometer that's causing it, the problem is that the memory stores the value of the potentiometer which is never changing, so when asked to move to a stored position it already thinks it's there?
Old May 15, 2008 | 01:12 PM
rparker's Avatar
Default RE: I used the instructions supplied and all pots work except...
When you say "instructions supplied" what instructions are you referring to, or am I being really dense! It'as quite possible that I have missed some instructions somewhere...
Richard
Old May 15, 2008 | 02:18 PM
rparker's Avatar
Thanks for the procedure.
I just went and followed the advice and I get a red light at all seat limits! I did have to push the memory button twice at some of them, but that may just be me not pushing hard enough the first time.
It's really annoying that the seat will move, just not under memory!
Are there any more suggestions for me to try?
Cheers,
Richard
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Clamdigger
Sep 12, 2015 03:43 PM
wcourt3010
Sep 9, 2015 04:34 PM
1100me
Sep 7, 2015 06:26 AM
