Engine idle high and rough
Old Dec 31, 2011 | 04:42 PM
avtuvy's Avatar
Default Engine idle high and rough
1996 XJ6 located in Israel, engine goes to 2000 rpm as soon as it is started, it idles rough and smokes. error code is P0727. Please help
Old Dec 31, 2011 | 05:09 PM
Doug's Avatar
I won't be much help but sensing a bit of urgency I thought I'd offer a reply until someone better comes along
Enter P0727 into the search box at the top of the page. I know the subject has comes up previously. The code relates, I think, to an engine speed vs road speed discrepancy...or something like that. Perhaps to be expected if the idle is stuck a 2000 rpm?
Common faults causing a high idle are the idle air control valve (I think Jaguar uses a different name...my mind is drawing a blank) fault and/or a dirty throttle body.
Others will chime in
Old Dec 31, 2011 | 05:29 PM
Jimmerman's Avatar
Had a similar problem with my 2000 S-type. Put a $25 can of BG-44K in the fuel tank. Car runs like new. Didn't really expect much but it really seems to have worked well.
Old Jan 1, 2012 | 11:40 AM
sparkenzap's Avatar
Try those things forst, then check back for more indepth suggestions.
cissdm
May 3, 2016 06:02 AM
user 652867429824
Sep 5, 2015 12:53 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
rachelstr
Sep 3, 2015 12:59 PM
