engine swap
Old May 24, 2013 | 09:09 AM
x300man's Avatar
Default engine swap
a friend of mine wants to put 4.0 engine into his 3.2 this should be a straight enough swap yes? would it be to much for gear box or are the ratio"s same or would it better with the 4.0 ltr box at back of it, what else should be exchanged, any help would be gratefull
Old May 24, 2013 | 02:33 PM
sogood's Avatar
The gearbox on the 4.0 litre car is a different beast to that on a 3.2 in that it's electronic, with sport mode, unlike the 3.2. Also the diff ratio is different on both cars, so, ideally, to get the best from the swap, I imagine you'd have to chage everything.
Not sure about ECU's etc. although strangely enough, the throttle body is exactly the same. I suppose the difference is in how they are "instructed" by the cars computer.
Not sure of any other major differences off the top of my head. I have a 3.2 donor, so the above main bits aren't a lot of use to me as my daily driver is a 4.0 litre.
Old May 25, 2013 | 03:28 AM
XJRengineer's Avatar
The hydraulic only ZF4HP22 gearbox from the 3.2L will cope with the performance of the 4.0L engines and would therefore make the change easier than fitting the electronically controllled ZF 4HP24E from the 4.0L car, as you would also need the gearbox harness and transmission ECU.
Old May 25, 2013 | 08:18 AM
sogood's Avatar
I'm happy to hear that and glad to be further educated! So it seems, if push comes to shove, I do in fact have a donor box that will work with my 4.0 litre engine? Of course, then there would be the electronics/wiring to sort out, yes?
FrickenJag
Jun 16, 2025 02:15 PM
cissdm
May 3, 2016 06:02 AM
sogood
Sep 15, 2015 07:35 AM
bdboyle
Sep 4, 2015 06:16 AM
Bowman
Sep 3, 2015 03:17 PM
