European parts might not fit?!
Old Jun 29, 2013 | 08:52 AM
Selsoft's Avatar
Default European parts might not fit?!
The rear was not feeling right, so, I decided to replace the strut.
Order shocks from the US, but, the coils springs from Europe [KYB Europe RC5326]. Took the parts to a shop [I don't have a workspace right now].
I was told the coil springs did not fit/match.
A. Has anyone fitted coil springs from KYB Europe?
B. Do you know of part-number/brand that would fit US market '97 VDP?
Old Jul 3, 2013 | 07:01 AM
Selsoft's Avatar
I found a list of models where the part would fit, and VDP is not on it :
Notes Make Model Year Variant Bodystyle Type Engine
Jaguar XJ 1989 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1990 XJ 40,81 [1986-1994] Saloon Saloon 6 3.2 24V 3239ccm 199HP 146KW (Petrol)
Jaguar XJ 1990 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1991 XJ 40,81 [1986-1994] Saloon Saloon 6 3.2 24V 3239ccm 199HP 146KW (Petrol)
Jaguar XJ 1991 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1992 XJ 40,81 [1986-1994] Saloon Saloon 6 3.2 24V 3239ccm 199HP 146KW (Petrol)
Jaguar XJ 1992 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1993 XJ 40,81 [1986-1994] Saloon Saloon 6 3.2 24V 3239ccm 199HP 146KW (Petrol)
Jaguar XJ 1993 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1994 X300 [1994-1997] Saloon Saloon 6 3.2 3239ccm 211HP 155KW (Petrol)
Jaguar XJ 1994 X300 [1994-1997] Saloon Saloon 6 Sovereign 4.0 3980ccm 241HP 177KW (Petrol)
Jaguar XJ 1994 X300 [1994-1997] Saloon Saloon R Super Charged 4.0 3980ccm 320HP 235KW (Petrol)
Jaguar XJ 1994 XJ 40,81 [1986-1994] Saloon Saloon 6 3.2 24V 3239ccm 199HP 146KW (Petrol)
Jaguar XJ 1994 XJ 40,81 [1986-1994] Saloon Saloon 6 4.0 3980ccm 222HP 163KW (Petrol)
Jaguar XJ 1995 X300 [1994-1997] Saloon Saloon 6 3.2 3239ccm 211HP 155KW (Petrol)
Jaguar XJ 1995 X300 [1994-1997] Saloon Saloon 6 Sovereign 4.0 3980ccm 241HP 177KW (Petrol)
Jaguar XJ 1995 X300 [1994-1997] Saloon Saloon R Super Charged 4.0 3980ccm 320HP 235KW (Petrol)
Jaguar XJ 1996 X300 [1994-1997] Saloon Saloon 6 3.2 3239ccm 211HP 155KW (Petrol)
Jaguar XJ 1996 X300 [1994-1997] Saloon Saloon 6 Sovereign 4.0 3980ccm 241HP 177KW (Petrol)
Jaguar XJ 1996 X300 [1994-1997] Saloon Saloon R Super Charged 4.0 3980ccm 320HP 235KW (Petrol)
Jaguar XJ 1997 X300 [1994-1997] Saloon Saloon 6 3.2 3239ccm 211HP 155KW (Petrol)
Jaguar XJ 1997 X300 [1994-1997] Saloon Saloon 6 Sovereign 4.0 3980ccm 241HP 177KW (Petrol)
Jaguar XJ 1997 X300 [1994-1997] Saloon Saloon R Super Charged 4.0 3980ccm 320HP 235KW (Petrol)
Old Jul 3, 2013 | 07:52 AM
Doug's Avatar
In what respect? Too long long, too short? What was the difficulty?
You can see if the Jag dealer can still get orignals.
Or try a Jag parts specialist: Coventry West, Motorcars LTD, Paul's Jaguar, Welsh Jaguar, etc.
Old Jul 3, 2013 | 08:04 AM
Doug's Avatar
Not even the official Jaguar parts catalog breaks out the VDP individually with respect to coil springs. Four different rear springs were used: 6 cylinder normally aspirated, 6 cylinder supercharged, V12 comfort, V12 sports.
Any of those choices should physically fit into place. If what you received won't fit I'm inclined to say they simply sent parts that are totally incorrect.
Old Jul 3, 2013 | 09:11 AM
Selsoft's Avatar
I found out this after getting the part, but, the '97 VDP part is JLM12257 spec'd at 390 mm length.
The part I got is spec'd at 347 mm length, fitting the list I posted earlier.
This is what I ordered, but, they had mistakenly listed VDP in the cars that fit.
KYB EUROPE Part # RC5326 More Info K-Flex; Spring Design: Coil Spring; Thickness/Strength 1 [mm]: 16; Outer Diameter [mm]: 134; Length [mm]: 347; Sold individually
Category: Coil Spring
Old Jul 3, 2013 | 09:39 AM
Doug's Avatar
Sadly this sort of issue comes up very often with aftermarket springs.
The JLM12257 seems to be applicable to a large array of Jags:
Part search results for jlm12257 - Jaguar Classic Parts UK
Off hand it sounds like KYB is selling (shorter) springs that might be correct, or more nearly correct, for the Sports/XJR suspension.
Old Jul 4, 2013 | 09:56 AM
Selsoft's Avatar
Yes, it seems like what I have in hand would fit a lot of Jags.
Old Jul 4, 2013 | 07:42 PM
doc's Avatar
doc
Sometimes you get new springs that are shorter when compared to the original springs but after install the car sits higher
recently had that with the wife's Jeep GC
Old Jul 5, 2013 | 12:07 AM
Selsoft's Avatar
I will keep that in mind, good to know.
XJsc-guy
Nov 23, 2015 01:56 PM
KarimPA
Sep 12, 2015 08:15 AM
prettydaim
Sep 4, 2015 09:13 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 07:47 PM
TC Johnson
Sep 2, 2015 09:30 AM
