Hi, when sitting in the car at idle, I sometimes hear a clunck noise when the fans engage and can also slightly feel it. Unfortunately with the bonnet up and me listening it hasn’t happened, with the car stopped the fans move freely when I turn them by hand, is this a bearing or something on the way out? Any suggestions?
There was a TSB (wiring modification) to engage the fans with the ignition switch to eliminate the 'blown-fuse' fault when the fans jumped to high without the fans already running at low speed first.
There is a distinct sound when the fans go into high speed, which I guess could be described as a "thunk" . It always seems to me to be a combination of the relay operating, combined with the extra load on the fan assembly and the charging system. Could be a different "thunk" from the one you are talking about, as the one I hear doesnt sound concerning at all.
