Fan clunck
Old Apr 10, 2021 | 04:05 PM
Jagguyx300's Avatar
Default Fan clunck
Hi, when sitting in the car at idle, I sometimes hear a clunck noise when the fans engage and can also slightly feel it. Unfortunately with the bonnet up and me listening it hasn’t happened, with the car stopped the fans move freely when I turn them by hand, is this a bearing or something on the way out? Any suggestions?
Old Apr 10, 2021 | 04:37 PM
Parker 2's Avatar
There are little balancing weights that may have come loose but you wouln't be able to account for them missing
Someone recently had a pic of the fan motor top assembly but I can't find it
The X308 fans can be used as a replacement that someone recently covered in a thread
https://www.jaguarforums.com/forum/x...y-x300-244123/
Old Apr 10, 2021 | 08:58 PM
motorcarman's Avatar
Maybe the A/C compressor is engaged and the fans start running?
Old Apr 10, 2021 | 09:02 PM
There was a TSB (wiring modification) to engage the fans with the ignition switch to eliminate the 'blown-fuse' fault when the fans jumped to high without the fans already running at low speed first.
Old Apr 10, 2021 | 11:28 PM
Parker 2's Avatar
The TSB that Motorcarman ( Bob ) is referring to has a jumper wire on the 2 wire freon low pressure switch
You may not even have this low pressure switch
If you need this jumper a X300 just came into the local salvage yard and I can mail it to you if you PM me
http://www.jagrepair.com/images/TSB/...%20Failure.pdf
Old Apr 12, 2021 | 04:19 AM
countyjag's Avatar
There is a distinct sound when the fans go into high speed, which I guess could be described as a "thunk" . It always seems to me to be a combination of the relay operating, combined with the extra load on the fan assembly and the charging system. Could be a different "thunk" from the one you are talking about, as the one I hear doesnt sound concerning at all.
jagtoes
Sep 24, 2018 04:28 PM
SirJohn
Oct 31, 2017 05:31 PM
dneider
Aug 15, 2017 08:49 AM
zathras
May 4, 2014 08:41 PM
Lanny
Dec 25, 2012 08:03 PM
