Are your fans on after shutdown
Old Sep 24, 2018 | 08:19 AM
jagtoes's Avatar
Default Are your fans on after shutdown
I've only heard of maybe 1 or 2 instances where the radiator fans have run after shutdown. I have never had this occur yet but was wondering if others have had this as a normal experience. Now up north our summers usually hit 80*F-90*F with some spikes of 95*F or better but not a normal condition. Regardless of the temps as I pull into my garage after a run my engine temp is between 200*F and 205*F as I put the top up. I don't get out of the car but I think I can hear the fan running but as soon as I shut down there is no fan noise and getting out of the car and walking around the front it is quiet. Understanding the fans are variable speed I couldn't find what temps the fan speed increases and what temps they shut down. Also my AC system is always on Auto so I assume the fans are always on. Just curious as to others experiences.
Old Sep 24, 2018 | 09:01 AM
shemp's Avatar
I have never witnessed the fan running after the engine has been turned off.
Old Sep 24, 2018 | 12:46 PM
jahummer's Avatar
Mine does it frequently but not all of the time
Old Sep 24, 2018 | 12:52 PM
110reef's Avatar
It is pretty hot here. I am not aware of it happening, but it is possible I did not notice.
Old Sep 24, 2018 | 01:05 PM
Brutal's Avatar
It is normal and usually will run for 90 seconds give or take, sometimes alot more or less.. They also come on for ac system head pressure not just engine temp. All control by the ecu software
Old Sep 24, 2018 | 03:09 PM
Ranchero50's Avatar
I've only heard mine running hard at idle before shutting it off on miserably hot / humid days when the A/C is running. Never after shut off.
Old Sep 24, 2018 | 03:55 PM
mrsclark's Avatar
Recently my thermostat went out, that was the only time I actually heard the fan running after shut down. Even Texas summers at 110F, I could not hear the fan. Once the thermo went, it got very loud.
Old Sep 24, 2018 | 04:28 PM
hafren's Avatar
I've only seen it once or twice but I have to lift the bonnet to see Normally I cant hear anything beyond the exhaust expansion/contraction clanks.
Fastlane'scat
May 23, 2017 07:33 AM
randyk
Aug 12, 2012 04:08 PM
IanP
May 2, 2012 04:35 PM
Chuckben
Apr 13, 2012 04:01 PM
Moo
Sep 7, 2010 11:55 AM
