Front side indicator and one same side front indicator bulb remain on
Old Nov 20, 2015 | 01:59 AM
Jens boy's Avatar
Default Front side indicator and one same side front indicator bulb remain on
Hi. My XJ6 has a problem. All of a sudden, the passenger's side indicator, and one of the bulbs in the passenger's front indicator are on permanently, even when the ignition is turned off. The only way to extinguish them is to disconnect the battery. The left turn indicator also blinks fast, as if there is a bulb out. I tried removing what I thought were the appropriate fuses, but only affected the indicators, and failed to extinguish the two afore mentioned lights. Also, how do I remove the side indicator in the guard to check the wires? All advice gratefully accepted.
Old Nov 20, 2015 | 06:10 PM
Jens boy's Avatar
Hi All. This morning, after a drive, all seems normal and working properly in the left turn indicator, side and front. So far it looks like my car has exercised its option to heal itself. Cheers.
Sean W
Nov 14, 2015 08:28 PM
blackshortbed
Oct 29, 2015 09:04 AM
AnD3rew
Oct 28, 2015 10:22 PM
Artigiano
Oct 27, 2015 03:44 PM
Dale Konkol
Oct 25, 2015 11:12 AM
