Fuel sender shows 3/4 full when tank full
Old Oct 25, 2010 | 05:28 PM
Simprof's Avatar
Default Fuel sender shows 3/4 full when tank full
Is there an easy fix for this problem, I've heard you can clean them but is that posible and if so where can I find it?
Sorry car is an XJR 1997
Old Oct 26, 2010 | 08:21 AM
Turftech's Avatar
If you remove the panel at the front of the trunk, you will see the sender unit right in the centre of the tank facing you. There is a locking ring that needs to be turned to the left to remove. Be careful not to damage it! Sometimes a long screw driver works, but I have been known to use a punch to carefully "persuade" it to turn. I would recommend you run the tank down to as low as you can before removing the sender, and remember fuel is explosive! Use great care when handling gasoline. I have never been able to simply clean a sender unit, and the cost is not very prohibitive to simply replace the whole unit and gasket and be done with it for another 200'000 Kms. Just be sure to snug it in well when tightening the lock ring. And make sure it is spotlessly clean.
Not a big job by any means. Have fun!
Old Oct 26, 2010 | 08:57 PM
motorcarman's Avatar
Here is what used when these cars were new
bob gauff
File Type: pdf
Old Oct 27, 2010 | 09:07 AM
Turftech's Avatar
bob gauff
That's a great file to have on hand. Thanks Motorcarman! I love how they only allow .65 hours to do the tests!
Old Nov 4, 2010 | 05:46 AM
jaggachafen's Avatar
I hav e changed lots of these
Always solved the problem but i will try the FIX aswell though my gauge just started to do the same
Old Nov 4, 2010 | 01:21 PM
Simprof's Avatar
Thanks everyone where would you go for a replacement? I'm in Canada but am only 10 minutes from Buffalo, plus what shuld I be paying for the unit and seal..
Bill
Old Nov 7, 2010 | 04:52 PM
SNG barrat would probably work just fine for you to order from.
It´s not expensive that is all i know
Old Nov 15, 2010 | 12:54 PM
Uppdate to this one... My car did the same thing on the first fill for this season. It has been sitting for 6 mmonths. I drove near to empty and the next time i filled it it came right up to the top.
Worth a try
Old Nov 15, 2010 | 02:56 PM
Simprof's Avatar
I pulled the unit out last Friday and cleaned the contact with a fast dry elecical cleaned then hook-up the gauge in the car empty now reads empty and full reads full. I also put a little more tension on the contact piece..
Old Nov 15, 2010 | 05:36 PM
Turftech's Avatar
Nice work! It sure is nice to just plain fix something, rather than replace it eh? I have been known to spend hours fixing a $2 part...
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
hen555
Sep 7, 2015 11:13 PM
alpecsa
Sep 7, 2015 11:55 AM
deanh
Sep 6, 2015 08:20 PM
