? Gauges real time or semi like XK8
Old Oct 20, 2014 | 07:22 PM
weisberg's Avatar
Question ? Gauges real time or semi like XK8
My 2002 XKR temperature gauge wasn't real-time, quite a disappointment. JagWrangler had an upgrade kit to change that called Real Gauge.
Sooo, the XJ6 has more gauges (great!) but I am wondering if any of them are effectively placebos or so slow as to be of little use before you are in trouble...
Old Oct 20, 2014 | 08:40 PM
RJ237's Avatar
Just guess. I use a Ultragauge in my XJ6. It monitors temp. among other things and has an alarm function. Also reads and deletes codes.
UltraGauge OBDII Scan tool & Information Center
Old Oct 20, 2014 | 09:24 PM
Doug's Avatar
They're idiot gauges.
The earliest X300s (maybe first 3-4 months of production?) had a real oil pressure gauge but Jag then went to an idiot gauge.
The temp gauge on X300s has been an idiot gauge all along.
As it happens the oiling systems and cooling sytems are so reliable on X300s it hardly matters, IMHO
Old Oct 23, 2014 | 05:17 PM
al_roethlisberger's Avatar
Yep, and I plan to just use an OBDII app on my phone via Bluetooth at some point. ...more for "fun" and interest than fault monitoring.
Old Oct 28, 2014 | 09:21 PM
SleekJag12's Avatar
The red "low coolant" light on the right side stack is probably more useful than the gauge. If that comes on, you've sprung a leak and should stop immediately, even though the gauge would still read "normal" for some time.
kelliott
May 31, 2022 05:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
David Thompson
Sep 3, 2015 07:48 PM
Bcrary3
Sep 3, 2015 03:48 PM
