Growling noise and weird startup
Old Oct 28, 2013 | 02:32 PM
JB Young's Avatar
Default Growling noise and weird startup
This past Saturday (two days ago) I took my 1995 XJ6 in for an oil/filter change and new front brakes pads/rotors. Within 20 miles of driving it I noticed two issues:
1. Last night, while parallel parking it to go to dinner, I put it in reverse and hit a small bump. Suddenly the car started making a low-pitched growl and was much noisier overall than it had previously been. The noise is not related to engine speed, and I popped the hood to listen to the cooling fans, but was unable to determine if they were the cause. The cooling fan housing is broken on my car, so it tends to make more noise than it should anyway. This extra noise and growling is constant now.
2. Twice this morning, upon starting, the oil light came on, the accelerator pedal would not work, and shifting the gear shift did not shift the transmission. A restart immediately fixed the problem both times.
Any ideas?
Old Oct 28, 2013 | 05:52 PM
OK, my thoughts this early in the morning.
When the oil filter was removed/replaced the mechanic may have accidently disturbed the wiring that is VERY close, and related to the oil switch and the TPS (Throttle Position Sensor).
This TPS on the 4ltr also controls the transmissions behaviour???.
The growling, weeeeell, some persistant investigation is needed here.
The fan shrouds repaired would be a good starting point.
Unplug the 2 fans, observe if the "growling" is still present, thus eliminating them from the process.
Ask what spec oil was oil was used, as sometimes a too heavy weight oil will case weird noises. I run 10W40 in all my Jags all year round.
Lastly, and my favourite. How long since the trans fluid was changed???????. That alone can create havoc with noises in any car.
Old Oct 28, 2013 | 09:11 PM
jvitez's Avatar
Mine made a noise that could be described as growling that was due to worn out electric fan motors. Unplug the fans, start the engine and see if the noise disappears.
Old Oct 30, 2013 | 07:52 AM
JB Young's Avatar
The passenger side cooling fan is toast. Guess that means I get to replace both fans and the shroud since that's how it's sold. Don't know anything yet on the shifting problem, but it hasn't happened again.
Old Oct 30, 2013 | 08:21 AM
Doug's Avatar
Used fans come up on Ebay often, usually for less than $100
Old Oct 31, 2013 | 07:59 AM
JB Young's Avatar
Thanks all for your responses.
Doug --
The shroud is broken on my car anyway, and rattles terribly, so I will just use this opportunity to replace it and both fans. In fact, the unstable shroud could have contributed to a shorter than possible life for the bad fan.
Poet
Feb 7, 2025 02:18 PM
sadepol01
16
Nov 22, 2024 05:05 PM
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
