Heated seats
Old Jan 4, 2018 | 11:50 AM
SirMexicano's Avatar
Default Heated seats
For those that have functioning heated seats how warm do they actually get. I can not tell if I can feel them or not as they might need to be repaired.
Old Jan 4, 2018 | 12:19 PM
aholbro1's Avatar
If you can't feel it, it isn't working
Old Jan 4, 2018 | 01:50 PM
Lady Penelope's Avatar
There are 5 fuses involved . Will start with driver seat first because that's my favorite one as a NAS ( North American Standard ) option as there are others .
# 6 / 5 amp LH Heelboard Fuse Box
# 3 / 20 amp RH Heelboard Fuse Box
# 4 / 20 amp RH Heelboard Fuse Box
# 9 / 25 amp RH Heelboard Fuse Box
# 12 / 10 amp RH Heelboard Fuse Box
To read the heating element read for resistance at socket 9 ( black wire ) through 10 ( red wire ) of the front seat control module connector SM1 - D located under the seat
You don't want to see a complete open ( high ) or complete close ( 0 ) on the element .
Non Premium seats do not have a seat control module , just 2 fuses and a relay
# 5 / 10 amp Trunk Fuse Box
Relay location under the seat
To read the element you would read resistance from the Orange / Pink wire at the relay to ground . You will be reading through a parallel circuit path for the dash switch light
Editing
Attached Thumbnails Heated seats-x300-seat-heat-untitled.png   Heated seats-x300-seat-heat-2-untitled.png   Heated seats-x300-seat-heat-relay-untitled.png
Old Jan 13, 2018 | 03:13 AM
SleekJag12's Avatar
It seems to take about 5 minutes before I can feel any heat on the tushy and lower back. Then it feels real nice! Butt, after a while it can get a little too warm. Sometimes I have to switch it off, but it will eventually turn off by itself anyhow.
Smudge67
Dec 16, 2017 09:52 AM
Fairlane500
Dec 9, 2016 10:27 PM
04X-Type3.0
Dec 26, 2012 03:48 PM
truckdogg4
Feb 15, 2008 05:35 AM
