Help Opening Boot (Trunk) when battery flat
Old Jun 21, 2022 | 04:06 AM
Winalot's Avatar
Default Help Opening Boot (Trunk) when battery flat
Can anyone help me urgently, my battery is totally flat. How do I open the trunk or boot ? Obviously the key does not unlock it.
hope someone can help, I’m stuck and can’t even use jump leads.
W
Old Jun 21, 2022 | 04:14 AM
watto700's Avatar
G’day Winalot,
You could connect a battery to one of the terminals, on one of the fuse boxes, under the bonnet/hood and power the car’s electrics to get your boot/ trunk open.
Lubricate the lock and use it often to keep it working.
Cheers,
Jeff.
Old Jun 21, 2022 | 05:10 AM
Winalot's Avatar
Thank you, that did it. For future ref, left hand fuse box under hood, left hand front corner 15 amp fuse, furthest terminal, is connect live to battery.
Note to those saying why not use the key, if the battery is totally flat, the key does NOT work?
Thanks again
W
Old Jun 21, 2022 | 05:18 AM
watto700's Avatar
G’day Winalot,
Well done on getting your boot open.
They key should always work though it needs to be turned a full 90 deg. My boot lock was frozen from lack of use and I had to spend quite a
bit of time and a lot of WD40 to get it to free up and now I use the key often to make sure the lock works freely.
Cheers,
Jeff.
Old Jun 21, 2022 | 05:28 AM
Winalot's Avatar
Just had a look around trunk key, is it mechanical as well as electrical, ie it will unlock electrically and mechanically release the trunk. If so as you suggested it needs cleaning up. Sorry if I’m being thick, I’ve little or no info on the car except what I have downloaded, only the drivers manual, which doesn’t mention it.
W
Old Jun 21, 2022 | 05:33 AM
Winalot's Avatar
Thanks Jeff
Is the Problem at the key end or the latch end, it doesn’t turn 90 deg, I can sea lever running to the lock which only moves minimally when turning key.
Old Jun 22, 2022 | 05:46 PM
watto700's Avatar
G'day Winalot,
It looks like you need to go over the whole mechanism and clean and lubricate it. The manual/key mechanism on my car was pretty much jammed solid with dried grease and corrosion and it took quite a bit of work to free it up and for it to work properly.
Cheers,
Jeff.
Old Jun 23, 2022 | 02:46 AM
Winalot's Avatar
Thanks Jeff, but which end I’d the problem? The key end or the latch on the actual trunk, they seem to be connected by a rod. I guess when you turn the key fully the rod releases the latch ?
W
O&DR
Mar 9, 2021 09:44 AM
XKR2000
Sep 24, 2019 08:24 AM
Injekter
Apr 19, 2015 05:27 PM
Nicdilla
Dec 18, 2013 06:40 AM
haggis95
Jan 21, 2011 06:08 PM
